Results 1 to 8 of 8
Thread: Need Help with 4th Axis wiring X3
    Mar 2006
    I just purchased the 4th axis for my x3; it came with no wiring instructions. Dose anyone have the wiring diagram?
    Apr 2007
    UK
    CNCpilot
    When you fix the 4th driver next to the others, note the colour of the wires to the other motors and repeat in the same order for the 4th. You have probably realised the cable from the motor is to short, not a problem as it allows you to introduce a four way plug and socket and then a suitable length of cable to the driver, thus allowing the 4th to be removed away from mill when not in use.
    Mike
    Mar 2006
    Thanks for your help mike.
    Works great.
    Apr 2007
    UK
    CNCPilot
    Now you have your 4th working have a look at my post No611317, 13-5-09
    regarding setting up the table, and backlash
    Regards
    Mike
    Registered neilw20's Avatar
    Jun 2007
    The Plug.
    Now you can plug in the 4th axis ALWAYS turn off power before removing or inserting the 4th axis cable. The driver will last much longer that way.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jun 2009
    South Africa
    I have a diagram for any future queries.
    See attached.
    ps. Thanks to Rod from Syil Africa for the excellent support.
    Attached Files Attached Files
    Mar 2006
    Thanks for the diagram. This will be help full.
    Jun 2009
    South Africa
    Sure.
    1. 4th axis wiring questions
      By WGJ in forum Haas Mills
      Last Post: 05-06-2009, 01:51 AM
    2. Wiring Help
      By tz1238 in forum Stepper Motors and Drives
      Last Post: 11-22-2007, 07:14 AM
    3. Wiring help.....
      By fineartlig in forum Industrial Hobbies (Support forum)
      Last Post: 09-24-2007, 12:21 PM
    4. Y axis connector wiring
      By metalworkz in forum Syil Products
      Last Post: 05-27-2007, 09:45 PM
    5. CNC wiring?
      By stdly in forum General Electronics Discussion
      Last Post: 02-18-2006, 03:44 PM
