Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 05-04-2009, 04:09 AM
srbob is on a distinguished road
Exclamation X4+ 4th axis setup
I am having trouble with my 4th axis when using my new X4+ everything seems to be set up correctly but when i try and change the axis it always goes to a greater angle than i asked it to do.
I am using Mach 3 software to run the machine and i think it a setting in that that i may have incorrectly set up. I have looked through all the options i cannot find what i have missed. I have told it that the 4th axis is angular in the general config.
any help anyone can give would be greatly appreciated
Old 05-04-2009, 06:34 AM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
maybe the motor is not configured properly, try the following:
put your 4th axis scale at zero.
goto settings screen (alt-6) and press the set steps per unit button (bottom left of the screen)
then select the A axis and tell the wizard to move 100 units
using the scale in the 4th axis read how far it moved and enter this value
accept the change
Now move the axis any desired amount and verify if its correct. After a couple of iterations of this procedure you should have a pretty accurate 4th axis, no need to do it more times because you will start jumping between two similar values each time.
good luck
Old 05-04-2009, 09:34 AM
syil is on a distinguished road
where are you get the config flies.
do you have contact info,then we can sent config flies for you...
Direction,Commitment,Follow through
Old 05-04-2009, 09:56 AM
thanks peu, thanks syil.
I have tried as Peu suggested and it seems to work well. However tryin 2 measure an angle accurately is quite difficult and was wondering wats a better way to do this
thanks syil. i believe i downloaded the config from the syil china website.
another problem i am now having is the 4 axis will move fine (eg G00 A90), however to move the axis back i have to do the reverse command (G00 A-90) rather than the command that i should be using (G00 A00). the 4 axis will only rotate to +/- commands from the point it was last at rather than working from a zero point.
Old 05-05-2009, 06:56 PM
PEU's Avatar
PEU PEU is offline
Originally Posted by syil View Post
...we can sent config flies for you...
WOW! you sure know how to train flies over there in China!
Old 05-05-2009, 07:01 PM
PEU's Avatar
PEU PEU is offline
you probably have the machine set up to use incremental coordinate system (g91)
Put in the init string (config>general config) G90, absolute coordinate system, and you should do fine. You can check the current status of your mill config in a string on the top right part of your mach3 screen.
Good Luck
Need Help!- Mach3 A axis (4th axis) setup? cadcamslawek Mach Software (ArtSoft software) 10 01-17-2012 08:23 PM
4th Axis Setup Help Cartierusm General Metalwork Discussion 2 03-18-2009 10:19 PM
Need Help!- My Axis Setup is Not Right Mr.Chips Machines running Mach Software 5 01-12-2009 07:24 PM
Best 4 axis and PC setup ? gunlocators Controller & Computer Solutions 13 08-05-2008 02:16 PM
Z Axis Setup musicmkr DIY-CNC Router Table Machines 5 06-09-2004 11:33 PM
