Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Syil X3 - Power Drawbar
    Jan 2007
    Hi all,
    I was having a conversation about making a power drawbar for my Syil X3 similar to the one that Hoss made, and it was mentioned that it wasn't possible without locking the quill.
    Can anyone tell me why? I'm a bit confused as to why it wouldn't work. Would that be because of the drill part of the mill where you can turn the handle to lower the spindle? I looked the X3 over a bit more, and on the front of the unit there is a handle for locking the spindle. Why can't this be locked and a power drawbar still used?
    Thanks,
    Wade
    Oct 2007
    UK
    You're correct, the mill does have a quill lock. The only issue with the spring retention type as you listed is that you've got to make sure that lock is 100% effective. If it isn't, you're going to force the quill downwards when you want to do a tool change.
    You might want to look at a means to lock the quill other than by the existing method. I decided to go with a small butterfly air impact wrench design for my draw bar as even though I do use the Tormach quick change system most of the time, I do swap other holders when I need to.
    Jan 2007
    Have you heard of any other type of Quill lock that anyone has made for the Syil X3?
    I really don't use any tooling than tormach, plus I want to build my own tooling rack, so the butterfly air impact wrench wouldn't work for me.
    Wade
    Jan 2007
    I'm still on my quest for a power drawbar, so I got to thinking about how the SX3 locks the quill. I looked on Grizzly's site and came up with the following pdf of the parts and pieces of the SX3.
    http://www.grizzly.com/images/partslists/g0619_pl.pdf
    It looks to me like the quill is actually locked against the Gear Shaft (Part #139 in the PDF) instead of the quill itself. That being said, it definately looks like putting 600 lbs on downward pressure on the top of the Drawbar bolt would be a bad idea. It could wind up stripping the toothed gears on the Gear Shaft.
    I am still determined to figure out a method to lock the quill down so that I can add a power drawbar and ATC to my mill.
    My main requirements is the ability to still use the quill as I want to be able to do tapping. But, if I can't do that, perhaps the quill assembly can be removed?
    Does anyone have any thoughts?
    Wade
    Registered BobWarfield's Avatar
    May 2005
    It worked great for Hoss on his X2. It has a quill too. Go look at what he did and copy it. You'll be fine.
    Cheers,
    BW
    Jan 2007
    Actually, it will not work the same as on the X2. On the X2, the handle that raises and lowers it raises and lowers the entire head. I have an extending quill on the X3. It's an entirely different kind of assembly. As I said in my previous post, if I were to put 600 lbs of force on the top of the quill, I risk breaking the gears that make the entire quill assembly move up and down.
    Not acceptable.
    So, I need to figure out some sort of different quill locking system that will support 600 lbs of downward pressure.
    Wade
    May 2007
    First, do you actually move your Quill up and down on your mill head?
    As for the locking "mechanism", the bolt that goes through the front will put ample pressure on the spindle sleeve housing to keep it from going anywhere. The entire housing around the spindle sleeve clamps down on the sleeve as it is tightened. What I am more affraid of is the quality of the factory bearings. After seeing the quality of the ones that came out of my grizzly, I don't think they will last very long with that force. I changed my upper bearings to tapered as well.
    On the other hand, maybe having the drawbar push down isn't the best option. What about finding the spring washers big enough to go between the spindle and the bottom of the spindle housing instead (Where the brass ring is). Then you could pull upwards to release.
    Jan 2007
    Yes, I do move my quilll up and down in order to use the tapping feature.
    Are you sure the bolt puts pressure on the spindle sleeve? It looked to me like it put pressure on the sleeve that controls the quill lever, in which case, the only thing that keeps the quilll from moving up and down is the gears on the quilt handle bolt meshing with the teeth on the back of the quill itself.
    Regardless of that, Hoss was able to make a drawbar type system like this and he still used the stock bearing if I remember correctly.
    Worse case scenario, I have to change out the bearings. Probably wouldn't be the worst thing anyway. I wonder how many hours of use is acceptable before a bearing replacement is necessary?!!?
    Not sure what you mean by spring washers between the spindle and the bottom of the spindle housing. Are you saying inside the head of the mill itself?
    Wade
    May 2007
    Ok then, what I suggested with the spring washers will not work then in your case.
    I have taken my mill apart completely many times and looking at the structure, you have the spindle, which goes into the bearings. Then that Assembly goes into the Spindle sleeve.
    That Assembly of - Spindle shaft, Bearings and Spindle sleeve - as a whole slides into the mill head casting. The hole that the spindle assembly fits into is slit down the side to the right. The bolt that you tighten for the Quill lock actually pulls the 2 halfs of the hole in the head casting together on that side to make a circular grip on the outside of the spindle assembly.
    The Spring washers I mentioned would work like this..
    If you look at your spindle from the bottom, you will see the Spindle that rotates, the spindle housing and then a brass ring that touches the head casting when completely pulled in. My thought was that if you do not use the quil as a drill head or tapping system, you could place the spring washers there for the drawbar tension (Between the Brass ring and the Casting). When not actuated, the springs are released and putting pressure on the collet to close on the tool. When actuated, you could pull the springs against each other from the top of the head, loosening the tension on the collet and releasing the tool. This will let the casting be the stop for the pressure instead of the opposite way of the spindle sleeve possibly being loose enough to slide down.
    This would only work if you are not using the quill though. The Drawbar system would be a permanent change to the mill tool change system.
    It is pretty easy to get the spindle assembly out. But as for the gear, it's only purpose is to move the quill up and down when released or loosened. The quill lock handle and bolt is the strength to lock it tight.
    Jan 2007
    So, are you saying that you would still use the same type of system to press down on the drawbar from the top as Hoss did on his X2?
    I'm liking this idea much more. I suppose I could use a stepper to run the spindle to do tapping similar to how Hoss did. It would likely be a bit better control than pressing the buttons.
    I'll have to see if they make beleville springs in that size tho.
    Wade
    May 2007
    Actually, I was thinking that pulling the spindle up would be the best option. I'll try to get a diagram of what I was thinking, but I am in the middle of a milling op at the minute. It may be tomorrow before I can post it.
    Oct 2007
    UK
    Regarding the quill lock on the front, when you tighten it the force of the action causes the two bushes to squeeze together (these have been known to jam and you can't get the quill down when you want to!) and this puts pressure on the quill and locks it against the quil bore in the head. I have taken out the quill handle drive completely as I don't do anything manual on the mill (have a tapping head if I need to do lots of threads) and the quill is 100% locked by the front lock.
    Whether is can withstand the force pushing down on it of the amount we're talking about...that's a tricky one to say. I wouldn't want to just rely on it myself. It could get awfully expensive on cutters if it came down even a small distance during a tool change and you're using a preset tool table.
    It's difficult to get the best of both worlds. If I was going down the Hoss route I'd be machining a section of the quill to allow mechanical fastening of the lower quill section to the bottom of the head. In theory you could do something where under normal operation it was fixed by this mechanism and then unbolt it to allow tapping.
  • Page 1 of 3 123 LastLast
    1. Power drawbar
      By Bigbloke in forum Bridgeport and Hardinge Mills
      Last Post: 03-14-2009, 08:36 AM
    2. X2 power drawbar
      By X2cnc in forum Benchtop Machines
      Last Post: 09-19-2008, 08:39 PM
    3. Power Drawbar Problems
      By Lou V in forum General Metal Working Machines
      Last Post: 03-11-2007, 11:14 PM
    4. power drawbar
      By fourperf in forum Bridgeport and Hardinge Mills
      Last Post: 03-21-2006, 09:28 PM
    5. Power DrawBar Mechanism
      By vmax549 in forum Bridgeport and Hardinge Mills
      Last Post: 11-18-2005, 06:10 PM
