Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 03-02-2009, 06:54 AM
Chipboy is on a distinguished road
Question Syil x4+ Closed Loop Servo retrofit ?
Hello everyone
I have been looking for a small milling machine for some time now, and am about to view a Syil X4 + machine, in the flesh as it were.
I was wondering if anybody out there had switched their machines over to using a closed loop servo system ?
Was it worth it, or was it just a pain with little or no gain in accuarcy or performance ?
i have seen various kits and such on the net and i know that installing some servo drives is not quite the plug and play thay make it out to be !!.
Also, has anyone heard conformation on the X6 release price and weather or not it will come with a brushless servo system fitted as standard ??
Cheers
CB
Old 03-02-2009, 11:38 PM
neilw20's Avatar
neilw20 is on a distinguished road
Already OK.
The machine given it's spindle speed and rapids is a nice balance between speed and stiffness.
You can make things jerk around more quickly and you will just start using the whole thing as a big spring as you change directions.
You are usually limited feed speed wise by the size of the cutters used.
Only if you increased it to above 25000 rpm would the extra snappy servos be of any use.
The steppers are fine. Only bad programming requires you to cut air at supersonic speeds.
Because there is no auto tool changer, higher speeds are a bit like trying to hitting a golf ball with a cricket bat.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 04-15-2009, 10:40 AM
syil is on a distinguished road
we also will release the servo soonly. for X4 series~~~
Direction,Commitment,Follow through
Old 09-12-2009, 03:01 PM
cliffy227 is on a distinguished road
http://www.cnczone.com/forums/showthread.php?t=89538
Open Loop to Closed Loop Stepper Conversion beamhome Stepper Motors and Drives 9 05-24-2012 02:46 AM
question on closed loop vs open loop (servo systems) boonie Servo Motors and Drives 20 11-09-2007 12:30 PM
plasma table retrofit: smart servos or closed loop steppers? Josh Leber CNC Plasma and Waterjet Machines 12 03-24-2006 09:25 PM
Lathe conversion - open loop vs closed loop bhowden General Metal Working Machines 7 03-21-2006 03:56 PM
Closed Loop Driver vs. Closed Loop Computer ojibberish Gecko Drives 3 06-08-2004 11:30 AM
