Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 02-19-2009, 12:23 PM
jharris is on a distinguished road
Z-Axis Trouble on Syil X4 (using Mach 3 CNC Controller Software)
Hello,
I have a Syil X4 CNC Mill, and I use Mach 3 CNC Controller Software by Art Soft Software. My mill has worked great for months, but I went to use it the other day and the z-axis got reversed. When I tell the mill to move up, it goes down, and down when I tell it to go up. The x and y axis work fine. Has anyone experienced this before?
Jon
Old 02-19-2009, 02:22 PM
Juka is on a distinguished road
Originally Posted by jharris View Post
Hello,
Jon
Check, Config>Ports and Pins>Motor Outputs>Z-axis - Change DirLowActiw
... to Red or Green and restart Mach.
Hope that helps!
Old 02-20-2009, 08:22 PM
syilcnc is on a distinguished road
you also can change the setting of mach3 as follow:
config -> homing/limiting -> reversed,find z,change it,than Z axis will work ok
Syil c6 cnc controller box needed!! gglynn81 Syil Products 2 09-18-2008 06:29 PM
Problem- Syil X3 Erratic Spindle Speed with Mach reithguitars Syil Products 9 07-16-2008 10:20 AM
Syil Controller - probe input? john_t_h Syil Products 4 03-01-2008 09:05 PM
Jerky Movement - Syil X3 Mach 3 Megaplow General CNC (Mill and Lathe) Control Software (NC) 1 01-09-2008 09:10 AM
Syil Controller Question mayhugh1 Syil Products 1 02-06-2007 01:39 PM
