Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-29-2008, 01:14 PM
fidia is on a distinguished road
Question X4 Speedmaster
Hi
I am considering buying a new CNC mill and wanted ssome feedback on the X4. Would it have the spindle speed to run a 3mm cutter in aluminium. Does anyone know anything about the 24000Rpm machine, pictures etc, all help and advice greatly appreciated.
Old 12-29-2008, 08:56 PM
john_t_h's Avatar
john_t_h is on a distinguished road
Originally Posted by fidia View Post
Hi
....Would it have the spindle speed to run a 3mm cutter in aluminium. .....
yep, I do it all the time. Just make sure you have the right feed rate and depth of cut. I found the attached spreadsheet helpful (if not a little conservative on the figures)
Old 12-30-2008, 06:29 PM
hughlss is on a distinguished road
hello fidia,
regarding the 24,000 rpm spindle speed version - it can be seen here on the Syil parent company site:
http://syil.com.cn/en/products.asp
Note that the speed range is 8,000 - 24,000 rpm
My best estimate as to receiving stock is around 3-4 months. We currently have the X4 plus.
Hugh
Syil UK
ps you're welcome to call again if you have further questions.
Old 12-31-2008, 04:57 AM
Re
I am very interested in the X4 plus, just not sure whether the 24000 rpm machine or the 3600 rpm machine would be best as I will be doing very small work up to larger work. I will be using cutters drom 2mm up to 12mm I reckon Then again im sure 12mm carbide end mills can be run at 8000 rpm.
I am in the process of getting a mew lathe at the moment so a mill is next on the listt.
Mabye the 24000rpm spindle is only for engraving work?
Old 12-31-2008, 12:31 PM
ataxy's Avatar
ataxy is on a distinguished road
if you plan on using 2mm cutter i would definitly go for the speedmaster
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 12-31-2008, 01:05 PM
But if i wanted to use a 16mm cutter and face mills also, do you think im asking to much ha ha!
Old 12-31-2008, 01:38 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi fidia.
Maybe you could have the best of both worlds. Get the regular spindle and then bolt on a high speed like this:
http://hossmachine.info/projects.html#engraver
CR.
Old 12-31-2008, 01:46 PM
Originally Posted by Crevice Reamer View Post
Hi fidia.
CR.
Im thinking thats the best solution ive seen yet. Its either that or buy 2 X4 mahines. Also what face mills can be used on the X4
Old 12-31-2008, 03:36 PM
ataxy's Avatar
i use a three insert 2inchs facemill on mine
Old 12-31-2008, 03:55 PM
m8kingit is on a distinguished road
How does this sheet correlate to the diameter of the cutter?
  #11   Ban this user!
Old 12-31-2008, 04:13 PM
I you type a cutter diameter and feedrate it should give you a spindle speed
  #12   Ban this user!
Old 12-31-2008, 04:50 PM
I think you type a cutter diameter and feedrate it should give you a spindle speed
Is there much setting up on an X4 when you get out of the crate? Degreasing, connecting wires etc?
