Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-27-2008, 09:48 AM
IMK1230 is on a distinguished road
Broken Motor to BallScrew coupler
Hello,
The Y Axis Stepping Motor to BallScrew coupler has broken on my X2 mill!
Anyone know where I can get spares in the UK please?
Or is this a generic part that is generally available in the UK and does anyone know of a supplier please.
Thanks IK
Old 12-27-2008, 11:13 AM
irving2008 is on a distinguished road
Try Zapp Automation or MarchantDice
Why not come visit the UK CNC Machinist community
Old 01-03-2009, 09:43 AM
Problem solution at Farnell's with Oldham couplers..
Very nice and much better than the originals
http://uk.farnell.com/huco/236p25-f/...pk4/dp/7002555
http://uk.farnell.com/huco/452p25-28...5x8/dp/7075870
http://uk.farnell.com/huco/452p25-24...1-4/dp/7075868
As always many thanks IK
Old 01-03-2009, 09:49 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Oldham couplers may introduce more backlash than the original helical type.
CR.
Old 01-04-2009, 10:18 AM
neilw20's Avatar
neilw20 is on a distinguished road
Stiffness Spec
Have a look at the spec sheet.
I do not know what torque you are transmitting, but the 1" part has over 1/4 degree deflection / nm of torsional stiffness.
I could not see a spec for backlash, but it wont take much wear before there is significant backlash.
Even before microstepping, at approx 0.001" / step (1.8 degrees) at half the rated torque you must expect 0.0003". Lightly loaded this may be OK but these couplers will deflect more than a helical coupler.
You will get what you pay for.
After looking at some stepper specs expect over one degree at high torque !
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-04-2009, 10:45 AM
Then what type, make, model of coupler should I get for the X2 Syil mill?
Old 01-04-2009, 10:56 AM
neilw20's Avatar
Google it.
I googled helical coupler.
Inside first link is:
http://www.ruland.com/ps_couplings_flexible.asp
Available locally for you at RS components
Investigate available shaft sizes of coupler carefully before ordering.
I'm sure there are other less expensive options.
Extra comment:
philbur has a good point.
Also the original couplers were crudely made with a slitting saw and hence have sharp corners in the edges of each slot, making a great place for a fatigue fracture to begin. I must polish mine. I am surprised they have lasted 18 months!
I never did like them. As for alignment about the best you can do is have the supports for the stepper all loose, tighten the coupler so that motor is aligned as best possible, then tighten the motor mounts.
But you need a new coupler first.
Bellow couplers are really expensive, but have impressive performance figures.
Crevice Reamer. Another better coupler no doubt.
Old 01-04-2009, 11:57 AM
philbur is on a distinguished road
Nobody has commented that you should look for why the coupling broke. The coupling will have a limit as to the amount of misalignment it can handle. A fatigue break would be the most likely cause, and that looks like it could be one. It you don’t want to mess with alignment issues then you need a more flexible coupling. Look for specs on maximum allowable misalignment.
Phil
Old 01-04-2009, 12:01 PM
You should definitely check the shaft alignment. Keling has some interesting helical couplers for sale cheap. I have not tried them, but his other products are first rate.
http://kelinginc.net/CNCPackage.html
CR.
Old 01-04-2009, 12:16 PM
Taking another look at the photo, if the setup has not been disturbed, it looks like the 2 coupling halfs have seperated, suggesting it was under considerable tension.
Phil
  #11   Ban this user!
Old 01-05-2009, 08:08 AM
sharpshooter90 is on a distinguished road
Phil
I agree- if the jam nut on the screw was loose, then the weight of the head would be hanging from the coupler. It may have not even shown up as backlash since the weight would keep thread contact all the time.
  #12   Ban this user!
Old 01-05-2009, 08:29 AM
It's the Y axis coupler that's broken. What does the weight of the head have to do with it?
CR.
Need Help!- pulley ratios : motor to ballscrew circlecn Industrial Hobbies (Support forum) 3 09-13-2008 05:32 AM
Broken spindle motor shaft ;( Legion99999 Syil Products 4 12-22-2007 05:49 PM
ballscrew/ motor matches? huios Linear and Rotary Motion 4 08-22-2006 07:52 PM
Coupler motor question MagTDK DIY-CNC Router Table Machines 7 08-07-2006 05:37 PM
Making a coupler between motor and lead screw nikolatesla20 Mechanical Calculations/Engineering Design 8 07-30-2005 01:05 PM
