| Syil Products Discuss Syil milling machines and conversion kits here! |
Does anyone uses X4 with mach2 controller? I need the following config: Motor tuning (x,y,z,4 velocity, accel, steps per unit, minimum pulse, direction precharge) Thanks in advance
__________________ gtcknives.com |
Thanks for answering, but what about that info (X4 Motor tuning (x,y,z,4 velocity, accel, steps per unit, minimum pulse, direction precharge) do you have it?
| well they areall in the xml but here is how mine is set x= step per 10160, velocity 150, acc 23.407972, step&dir pulse 0 y= step per 10160, velocity 150, acc 15.329724, step&dir pulse 0 z= step per 10160, velocity 61.62, acc 6.3730315, step&dir pulse 0 a= step per 400, velocity 1500, acc 200, step&dir pulse 0 spindle= step per 10, velocity 120000, acc 20725, step&dir pulse 0 by the way my machine is imperial not metric dont know if it as an impact but i dont think so
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
With metric units the steps/unit will be different. Simply ratioMETRICally change things I think. ![]() Don't change the A-axis unless you wish to use grads or radians (LOL) ![]() Just a guess but try these values: x= step per 4000, velocity 380 ??, acc ?? 23.407972, step&dir pulse 0 y= step per 4000, velocity 380 ??, acc ?? 15.329724, step&dir pulse 0 z= step per 4000, velocity 160 ??, acc ?? 6.3730315, step&dir pulse 0 a= step per 400, velocity 1500, acc 200, step&dir pulse 0 spindle= step per 10, velocity 120000, acc 20725, step&dir pulse 0 Just change the ?? until the stepper skips steps then use 75% of the value. Use a dial indicator with some precision know item on the table to confirm that the step value is correct for each axis.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
| mach2 | Mike Boarman | Machines running Mach Software | 6 | 11-17-2006 09:13 PM |
| need mach2 help | bo whipkey | Machines running Mach Software | 5 | 09-20-2006 01:30 PM |
| Mach2 Help | Cyclone | Mach Software (ArtSoft software) | 3 | 06-04-2005 12:43 PM |
| HELP....new to MACh2 | fattuna | Mach Software (ArtSoft software) | 6 | 09-17-2004 01:07 AM |
| Mach2 & IPM | georgebarr | Mach Software (ArtSoft software) | 4 | 03-24-2004 12:03 AM |
