Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-07-2008, 01:51 AM
GTC GTC is offline
GTC is on a distinguished road
X4: serial or parallel?
Please, someone knows if the conection cabe PC/mill is serial or parallel? My PC doesn't have such ports so I'll have to buy one USB adapter.
Thanks in advance.
Old 11-07-2008, 02:34 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile a USB parallel port will not work!
GTC,
It interfaces to a parallel port. a USB parallel port will not work!
If it is a desktop P.C. you can purchase a PCI parallel port.
http://tinyurl.com/64q2ja
If it is a notebook P.C. you can purchase a PCMCIA parallel port.
http://tinyurl.com/5u6pt4
Good Luck,
Jeff...
Old 11-07-2008, 07:40 AM
GTC GTC is offline
Originally Posted by jalessi View Post
GTC,
Good Luck,
Jeff...
Thanks Jeff
I think that still no work.. My notebook is HP, so the card is different...
Old 11-07-2008, 09:55 AM
ataxy's Avatar
ataxy is on a distinguished road
i am surprise! you are saying your hp notebook as no pcmcia slot?... then you could always try smoothstepper but i dont know how they perform on a syilx4 or you can do like i did and buy yourself a used desktop, i got for my shop three used hp desktop P4 2.8/512mb ram with some agp ati 9200/128mb for 175$ witch is a bit more the a smoothstepper but it does the job perfect
what you hp notebook model, also be carefull with notebook people have alot of problem with them and mach3
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 11-07-2008, 10:54 AM
GTC GTC is offline
Thanks for helping
Mine is Pavillon dv 6000,The card must have a dent to conect.
Old 11-07-2008, 11:31 AM
iGG1e is on a distinguished road
Sounds like the laptop has the newer Express card slot rather than PCMCIA.
Old 11-07-2008, 12:11 PM
GTC GTC is offline
So, what am I gonna do now?
Old 11-07-2008, 12:31 PM
ataxy's Avatar
well like i said i would highly recommend you look into the used desktop market i am sure you could get a P4 1.5ghz minitower with agp slot and 512mb ram for 100$ and you could still use your laptop for the rest of what you want to do, unless you got that laptop specifivcly for that purpose
Old 11-07-2008, 12:48 PM
GTC GTC is offline
I also think that's the right choice. But and the Autocad program? How can I make not having to buy another license?
Old 11-07-2008, 12:56 PM
ataxy's Avatar
why another license keep your autocad on the laptop you dont need it on your controller
  #11   Ban this user!
Old 11-07-2008, 01:07 PM
GTC GTC is offline
What kind of file should I use prior to Gcode?
gtcknives.com
  #12   Ban this user!
Old 11-07-2008, 01:18 PM
ataxy's Avatar
it depends on your cam software most of them support standard cad file like dxf, stp, etc, etc...
HELP!!! Cimco -- Use Parallel or Serial?? amf1277 Controller & Computer Solutions 4 10-23-2008 08:14 AM
Mac Intel chips for CNC - or > USB/serial/parallel converters anyone ? nick mulder General CNC (Mill and Lathe) Control Software (NC) 18 08-24-2006 09:18 PM
Parallel to Serial cbcnc General CNC (Mill and Lathe) Control Software (NC) 5 08-09-2005 11:21 AM
Serial or Parallel port drive Max General Electronics Discussion 8 11-02-2004 01:20 AM
Serial vs. parallel communication OCNC General Electronics Discussion 15 10-20-2004 06:53 PM
