| Syil Products Discuss Syil milling machines and conversion kits here! |
I'm finally getting around to setting up my C6B lathe and I've discovered that the info I have for motor tuning in Mach 3 is incorrect. My X was only moving 0.4mm when given the X1 command. ![]() To work out the right settings I need to know the following info: A. Steps per revolution: ?? B. Step Resolution: ?? micro steps C. Thread pitch:?? (A x B)/C = Steps Anyone have this info for the X and Z Axis? |
| John, Is the X direct drive or geared (belt or gears)? You are off by a factor of 2.5. Steps per mm = total steps per rotation / mm traveled per rotation The terms "per rotation" cancel out and leave you total steps/mm traveled. You should be able to find the mm pitch by setting up a dial indicator and measuring how far the crossfeed travels with one revolution of the leadscrew. The simplest thing might be to look at your current configuration and see what the current step factor is set for the X axis and multiply it by 2.5. Alan
__________________ http://www.alansmachineworks.com |
| Procedures to calculate steps per inch | DrStein99 | LinuxCNC (formerly EMC2) | 5 | 08-17-2008 08:53 AM |
| Need Help!- Calculate "Steps Per" In Motor Tuning | Burn | Mach Mill | 7 | 05-15-2008 10:25 PM |
| how do you calculate steps | cp465vw | Benchtop Machines | 4 | 11-27-2007 05:36 PM |
| Losing steps with Mach3 | CMPM | Mach Plasma / Laser | 2 | 07-20-2007 11:02 AM |
| Proper way to calculate steps/unit for belt drive? | MrBean | DIY-CNC Router Table Machines | 31 | 03-30-2007 10:48 PM |
