Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-01-2008, 04:07 PM
cvafiadis is on a distinguished road
Syil X4 and horizontal machining
Any one know if X4 is capable for horizontal machining, i mean if is a possibility to turn the mill head at any anount from the vertical position
christos
Old 11-01-2008, 05:29 PM
ataxy's Avatar
ataxy is on a distinguished road
no the head does not turn like on the SX3
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 11-02-2008, 04:04 PM
Then is any possibillity to make the head turn any modification for this.
and what can be the negative of this mod.
christos
Old 11-02-2008, 06:48 PM
philbur is on a distinguished road
What machining process are you intending to perform.
Phil
christos
Old 11-03-2008, 09:53 PM
squale is on a distinguished road
can you comment on the performance of the X4? how does it compare to the Smithy 622 ? I can't decide which one to go with
Old 11-03-2008, 11:16 PM
ataxy's Avatar
in all honesty you cannot expect none of those machine to come in perfect, they all have there little conception flaw but overall offer performance that are ok as long as you treat them the way they should be... like small machine if you want my point of view both machine are on par with each other and both will require you some tweaking and adjusting out of the box, both machine are more then capable to make quality part but as i said if you treat them right so basicly it comes down alot more to how you check it, adjust it, clean it and operate it ounce you got it and wich one will cost you less. also in all honesty i do not think that there is a great advantage in having the X4+ over the X4 since the front panel is in its first version and would definitly need to be able to interact with mach3 in order to become a usefull addition to the machine
edit:you should definitly start your own thread instead of posting inside others thread
ah one last point i highly recommend that you should not buy the 4axis with in head of doing full 4 axis operation so far it as only proven worthy of positionning but not full 4th axis work they really need to work on this one...
Old 11-11-2008, 04:17 PM
Ataxy i have to agree with you at both points x4+ not having any usefull advantage when working with mach 3
also the 4 th axis is as you says for positioning mostly.
christos
Old 11-13-2008, 08:06 PM
ataxy's Avatar
yeah thats a big down point i bought it to do 4th axis work not as a dividing head
Syil C6 Machining video - Map reader PEU Syil Products 1 06-14-2008 10:24 AM
Deawoo Vs OKK Horizontal LBB1234 General Metal Working Machines 8 05-22-2008 08:07 AM
OKK Horizontal or Toyoda robclemson General Metalwork Discussion 3 05-20-2008 10:25 PM
horizontal spindle endgrainguy G-Code Programing 3 03-28-2008 10:44 PM
Need Help!- Horizontal Machining Centers BaronMachine Haas Mills 4 02-06-2008 09:45 AM
