Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 10-24-2008, 03:42 PM
ataxy's Avatar
ataxy is on a distinguished road
machine goes over limit
as anybody got that problem where the machine (X4+/Mach3) does its operation then call a tool change, you do the tool change, and then instead of going to its g54 it just try to position it self from home and not its work offset.
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 10-25-2008, 03:00 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question code?
please post the code sequence you use.
there are a few gotchas that may not be obvious.
how do set up the offset for each tool?
going out, so answer won't be within 6-10 hours.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 10-25-2008, 03:33 AM
ataxy's Avatar
Yeah! Sorry about that i sort of made a double post on this one check the g-code section i made a thread that is all ready on the trail of the problem sorry about it.
little gcode problem i guess
Machine refpoints? Limit swithes? Simonetz Tamás Syil Products 7 04-29-2007 09:51 AM
EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE Epik General CNC (Mill and Lathe) Control Software (NC) 0 02-27-2005 05:20 PM
