| Syil Products Discuss Syil milling machines and conversion kits here! |
I have recently been using the 4Axis to engrave a scale on a 30mm dia bar, I found the when producing the numbers they appear to be, not quite right, sort of on an angle of 1-2deg. On further inspection I found quite a lot of backlash in the rotary table, so no big deal to adjust the worm and wheel to eliminate this, I thought! The worm wheel is not truly a worm wheel, it is a helical gear, with teeth which looked like they have been cut with a rusty nail, the burs on each tooth were so big, when I used a cloth to wipe the grease away they tore the cloth into shreads, OK, made in China you may say!!! After tidying the teeth with a needle file, cleaned up and re- greased, I re-assembled the unit into the housing, I still found that I was having trouble adjusting the backlash, I could adjust the worm to eliminate the backlash at zero position but in 180deg. position it was too tight, or running in clockwise was ok but in counterclockwise is was tight. On the rotary table side of the wheel assy. there is a thrust surface with an eccentric oil groove, however on the opposite side there is only a check nut without any form of thrust bearing or washer, the checknut face is not only running direct onto the housing casting, it is also machined out of square to the bore. This explains why it will run in one direction, but in the other direction it has no decent bearing surface. To overcome this I have ordered a needle thrust bearing which is 5mm thick, I can machine the checknut by 3mm to accomodate the bearing whilst still ensuring to keep the checknut within the bottom surface of the housing. I will take some photo's and post the bearing numbers etc. as I continue to try and make a silk purse out of a sow's ear. Martin
__________________ Martin |
| Jeff, Thanks for your constuctive comment. US$304 = AU$460 Shipping from USA to Aust. = US$70-100 Appox. total cost AU$600 One needle roller bearing AU$20 I will try my way first. Please understand I'm not whinning about Chinese manufacture, I'm aware of what I purchased. I'm only trying to assist others, so they don't have to waist time investigating the problem. Martin
| Further to my earlyer post. Note the worm wheel has straight teeth. Checknut with the shinny witness mark on one small area. Location of where the checknut sits against the housing. I should have the needle bearing tomorrow and will post my progress accordingly. Martin
| Early this year we shown the Syil X4+ w/4th axis at a local expo, we ran a demo using the 4th axis all day long and I can vouch for its repeatability, the key setting IMHO is low speed, I had it set up at 2turns per minute and never had a problem. Also you need to true it before using it, that will improve accuracy too. Pablo |
| Our company had a Shoptask with 4 axis CNC and the Shoptask CNC rotary table. It used a worm gear on an eccentric to adjust the backlash. It ran zero lash and was smooth all the way. The table was made in India, and the quality was surprisingly good. The shoptask design also allowed manual use and use of dividing plates as well. Look at www.shoptask.com under "tooling" part # ST32 |
Fixed the backlash, but still not getting the quality I would like from my engraving. Zero's appear slightly on an angle, Im using BobCam V21 to produce the text, vectorizing, then creating G code programe in BobCad. As a newbe to CNC there must be something I'm missing, should'nt the two axis's X and A move in an interpolation and not as separate movements (ie I&J command)? O() G90 G80 G40 G54 G53 Z0. T0 M06 S1600 M03 G90 G54 X0. Y0. G43 H0 D0 Z1. M09 G00X13.5965A34.3373 G01Z-0.2 F50 F200 X13.7252A34.8275 X13.8275A35.3972 A36.2428 X13.9694A36.7942 A37.3517 A37.9215 A38.4974 X14.0737A39.0734 A39.6493 A40.2313 A40.8072 A41.3832 A41.953 X13.9694A42.5105 A43.0619 X13.8672A43.6072 A44.2076 X13.7252 A44.7407 X13.5965 A45.1818 X13.4481 X13.2841A45.6413 X13.1089 X12.9288 X12.7492 X12.5787 X12.4211A45.1818 X12.2812A44.7407 X12.1681A44.2076 A43.6072 X12.0241A43.0619 A42.5105 A41.953 X11.9067A41.3832 A40.8072 A40.2313 A39.6493 A39.0734 A38.4974 A37.9215 A37.3517 A36.7942 X12.0241A36.2428 A35.7036 X12.1681A35.097 X12.2812A34.564 X12.4211A34.1229 X12.5787 A33.6695 X12.7492 X12.9288 X13.1089 X13.2841 X13.4481 A34.1229 X13.5965 G00A34.3373Z1. M05 M09 G53 Z0. M30
#10
| Not being exactly what you'd call experience in CNC either, but isn't it down to the configuration of the CAM program and the post it uses to implement the likes I and J commands in the final G code? Was it the bearing fix that sorted your backlash out? |
#11
| iGG1e, I will wait to see what response I get from the post regarding the program. Yes, I have fixed the backlash, but not entirely, I think there is some eccentricity in the wheel, there is a tight spot in the wheel, when I set it up so it drives ok over 360deg, there is a small amount of backlash in some areas. If I remove the backlash totally the motor stalls in some locations, I'm hoping with time the worm/wheel will bed in at the tight spots so I can re-adjust the worm accordingly. With the needle bearing in place it certainly drives consistant in both directions. The bearing is slightly too big in the bore by 1.4mm, I will make a sleave to centralise the bearing at a later date. I had to turn the checknut thickness down by 3.3mm to keep it below the housing face, this also left just enough meat for the locking screw to be effective. I can post photo's if anyone wants? Bearing no. Torrington (not sure of the spelling) 1 @ AXK4060 (Bearing) 2 @ AS4060 (Washers) AU$21 Martin
| X4+ 4axis | Martin Long | Syil Products | 3 | 08-26-2008 03:45 AM |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 03:35 PM |
| 4Axis Format G-code Example | louis14 | G-Code Programing | 0 | 07-26-2006 11:15 PM |
| L297-8 and 4axis BOB | aem_argentina | Open Source Controller Boards | 1 | 02-20-2006 09:55 AM |
| Cool picture of our 4axis | Gujustud | CNCzone Club House | 14 | 01-24-2005 04:22 AM |
