Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 10-08-2008, 09:37 PM
Martin Long is on a distinguished road
X4+ 4 Axis
I need to engrave a scale onto a 30mm dia. material, the scale is quite simple 0-50 in 10,5,1 increments just like a circular 150mm rule only 50mm. long.
I'm using BobCam V21 and Mach3.
In BobCad I have done the usual drawing as a rectangle the length of the circumference, the index distance between each line is around 1.8mm which is around 2deg.
When I run the programe on the mill the 4 axis always indexes to the long direction, instead of moving from A63.2 to A61.2 which is 2deg. it moves 358deg.
How do I make the axis travel to the next cut in the shortest direction without it doing almost a full circle?
Martin
Old 10-09-2008, 01:59 AM
neilw20's Avatar
neilw20 is on a distinguished road
Talking In the config settings.
Fiddle with the ticked boxes in the large Mach3 config page.
Ther is one marked shortest path/rotatin or something like that.
With a bit of trial and error it will go via the shortest rotation.
In the general logic screen set the A Axis to angular.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 10-09-2008, 02:41 AM
X4+ 4Axis
Neil,
Thanks for your response, would it be in General Logic Config. "Ang Short Rot on G0" ?
Martin
Old 10-09-2008, 09:23 AM
It works
Neil,
I tried what you suggested and it works a treat, thanks!!!
I have just engraved the scale, tomorrow I will try the numbers.
Thanks again
Martin
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 07:31 AM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 02:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 01:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
Options for 2 Axis Head (to make 5 axis) drewgarth DIY-CNC Router Table Machines 6 07-12-2006 01:37 AM
