Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 10-07-2008, 07:47 PM
Kevin Moore is on a distinguished road
removing nut on x axis
Stupid question. I received a new bearing housing and new bearings for my syil sx3 x axis ballscrew. Can't get the preload nut off to replace them. Am I doing something wrong or what?
Thanks,
Kevin
Old 10-08-2008, 03:28 AM
iGG1e is on a distinguished road
I doubt you're doing anything wrong. Possibly on here I made the comment that it appeared that someone had been swinging off the spanner when they tightened the one on mine. Trying to use the flat on the end to stop the ballscrew from turning was a waste of time.
Old 10-08-2008, 07:38 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
With a cutting disk, you can cut a slot into the end of the ball screw. Then use a common screwdriver to hold the screw while you unscrew the nut.
CR.
Old 10-08-2008, 10:19 AM
Thanks for the advise. I thought maybe I had lost it. I will cut the slot in the end of the ball screw.
Thanks,
Kevin
Old 10-08-2008, 10:35 AM
sharpshooter90 is on a distinguished road
If you have a lathe, just grip the ball screw in the 3 jaw.
Removing 4th Axis from Table, Fanuc 0i Jay Kyle Fanuc 4 09-02-2008 02:21 AM
Removing Tooling Mooser General Metal Working Machines 9 03-07-2008 09:16 AM
Removing a Gecko sploo Gecko Drives 4 12-11-2006 05:51 PM
Removing nut off ballscrew, I've never seen anything like it geohot Linear and Rotary Motion 7 12-23-2005 10:53 PM
Removing the armature ? Ken_Shea Servo Drives 3 10-10-2005 03:40 PM
