Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 09-23-2008, 07:44 AM
syil is on a distinguished road
SyiL X4 Speed Master 24000Rpm Release
SyiL X4 Speed Master 24000Rpm Release,More delivery and price info please consult local dealer from Syil.com
we also will present this machine in canton fair in next month,guangzhou.China.
xushuo
Syil.china
Name:	X4 Speed Master 24000rpm 1.jpg‎
ID:	66894   Click image for larger version
ID:	66895   Click image for larger version
ID:	66896   Click image for larger version
Direction,Commitment,Follow through
Old 11-12-2008, 11:11 AM
ddgman2001 is on a distinguished road
This looks like an interesting machine. Has anyone tried one yet? Are there any videos available?
Old 11-12-2008, 12:50 PM
iGG1e is on a distinguished road
So if my calculations are correct it'll take a 3.5 minutes to get up to full spindle speed...purely based on my SX3 experience.
It'll give you lots of time to sweep the workshop floor and such.
Old 11-12-2008, 02:50 PM
ataxy's Avatar
ataxy is on a distinguished road
why would it take 3.5min my x4 reaches 3500 in max 2sec
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 11-12-2008, 03:27 PM
Because they decided to fix the new design and conveniently brush the problems of existing SX3 based users under the carpet. Mine takes 30 seconds to reach 3000RPM regardless of what you settings you tweak in Mach.
Ultimately I will end up with a far superior motor controller, but there are times when I feel angry why we should be devoting resources to designing and building a replacement board for something that should do the job good money was paid for.
Certainly the speed management under CNC control is not fit for purpose and as such they should feel ashamed to have allowed it out of the factory. But then shame tends to take a back seat where money is concerned.
Old 11-12-2008, 03:55 PM
ataxy's Avatar
on that you are totally right and if you want my point of view it the biggest problem the chinese industry is facing
Old 11-12-2008, 04:08 PM
fastlanecafe is on a distinguished road
syil
We velly solly- promise do better next time.
Distraction- Confusion- foul up
Old 11-12-2008, 10:06 PM
X4 speed master not like X3 Or X4 mill machine use pully transfer the speed.
it is whole spindle and control by VFD.also None X4 machine have 3.5 minutes start spindle,the SX3 cnc during SIEG elecontrics problems,we hardly to fix it.
Old 11-13-2008, 01:27 AM
Martin Long is on a distinguished road
I hope they have fixed the X4+ E Stop, or it may take 3.5 mins. to stop it!!!!!!!!
Martin
Martin
Old 11-13-2008, 03:22 AM
So from that I take it that the problem with the CNC speed control is a Sieg problem? As far as I'm aware Sieg didn't produce a CNC version of the SX3 or any other model. You selected it as a platform for one of your CNC products. Therefore it is your responsibility to create a working package.
Although now with the Sieg KX3 out there, that certainly opens up new options of where to spend the money.
  #11   Ban this user!
Old 11-13-2008, 08:04 AM
sieg SX3 mainboard have 3 edtion,every time not infrom us and present it.
our CNC parts mainly it is pc interface board,funny it is some time we change another SX3,the cnc speed up faster.some of your will have long time problem.
we try to change pc interface board,but not every time ok.also we hardly back the SX3 elecontrics to sieg during it is ok for use on manual option.
that is why we give up and stop continue SX3 cnc.and have been solve this on X4 series CNC machine..
please email to me your edtion of SIEG board,i try to find a old pc interface board to suit your SX3.email to support@syil.com.cn
thank you for your consider,ok?
  #12   Ban this user!
Old 11-13-2008, 10:41 AM
ataxy's Avatar
ok as an owner of a X4+ i do understand that you did put some effort into the X4 serie to make it better then the previous model (SX3) but even on the X4 there is alot of bad design that should and could have been solved before putting it on the market and at minimum expense, i do understand that the mill is not as expensive as a 40000$ mill but it is also alot smaller and less capable then one wich mean that its actually a scaled down version of one, so thing like
1- unreliable spindle speed spec should have been notice before it as been put on the market, what i mean by that machine is advertised as 100-3500 but mine stall at 180 and seem to have a hard time keeping it speed stable at anything over 3300
2- less the well made 4th axis, i know you are probably working on getting this fix, but i doubt ill buy one from you since i allready bought one from you and it is not reliable as a 4th axis, yes i know its more of a positionning table but it is sold as a 4th axis and so it should be.
3- travel spec, machine is sold as a cnc not a manual machine but travel spec have more to do with manual operation then cnc operation, and this i am sorry to say but it is close to false representation
4-exterior nice, internal bad, i know one as posted about this, and i know that your ingineer as said that you are not suppose to have 100% contact on the gibs and this is true but the way the gibs are made you get at most 50% contact and not uniformly from one end of the gibs to the other creating pressure point on the gibs wich in the long run can cause premature wear of the z axis dovetail.
5-wire shield that are just hanging there... what the point of having wire shield if its hanging there open to chip and coolant... want an example my x axis limit switch wire shield get constantly filled with coolant each time and to make mater worse if i forget to empty the shield after a job and lift it do you know where the coolant would go... in the controller box, i am sorry to say but last time i heard coolant and electronic componnent don mix well together.
6-oh this is a good one more then unreliable front panel, i actually bought the X4+ thinking the front panel was in cnc mode able to work with mach3 but this is my mistake but honnestly it is in my point of view not worth the 1000$ difference from the X4 and dont point me at the mpg to justify the price difference first the movement of the mpg feels so bad and choopy it is really hard to use it manualy and keep a nice feed with it , also when used on a imperial machine x100 = 0.05 x10 = 0.005 and x1 = 0.0005 kinda weird and should not be like that. speed that do not match what mach3 is indicating and also cummulating error in the dro of each axis
anyway i hope you are really considering the problem that user have and are not just saying ' oh will try to fix that in the next model ' honnestly for me my only big ouch! on this machine so far have been the not conformed to spec speed and travel and the more then crappy 4th axis and i mean it, more then crappy
Problem- Syil X3 Erratic Spindle Speed with Mach reithguitars Syil Products 9 07-16-2008 11:20 AM
X7 release date ? acidcustom Syil Products 9 07-08-2008 05:15 AM
Syil X3 Mill Spindle Speed Calibration Procedure Chrisjh Syil Products 1 01-12-2008 02:54 AM
Default kernal speed in Syil inch profile thackman Syil Products 2 12-17-2007 04:41 PM
New release of CeNeCe PRO 1.07 DaniSaez CNC Wire Foam Cutter Machines 0 11-20-2006 05:49 PM
