Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 09-08-2008, 03:46 PM
lobecnc is on a distinguished road
Syil C6 not running smoothly yet
Hello,
Just received my new Syil C6, connected it all up and was running some manual tests. I have been using Mach3 for some time already on my small sherline.
Before starting the tests while putting the stepper motor brackets on I noticed that the Z axis is pretty easy to turn by hand, which makes sense as it is a smaller ballscrew with less to move.
The X axis however was quite stiff, and I seem to be able to get it to run a little easier by not tightening the stepper motor shaft cap screw and coupling, which may mean an alignment problem with the bracket.
Anyway, decided to go ahead and test the electronics so I downloaded the latest xml for the C6 from Syilamerica and ran Mach3.
I can rapid in Z but is is not smooth and when pressing the jog arrow it will change direction on its own.
The X axis moves when I jog, but will not rapid at all, and also changes direction even though I am pressing the same arrow for manual jog.
Where do I plug the Spindle encoder in on the Syil box, I see no other inputs except A and Y.
Any help is much appreciated.
Old 09-09-2008, 09:38 AM
Latest info
OK, I have the spindle encoder plugged into the Y input and it is working.
I still have the Jerky stepper motor problem with the standard SyilAmericaC6 profile.
As I mentioned, I can rapid in Z but even with Z when pressing the Jog arrow I get sporadic reversal of direction.
No Rapid at all on the X axis, and very jerky jog.
I use the same laptop for my Sherline and it works fine, so I know the laptop is fast enough for Mach3.
Old 09-09-2008, 09:55 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi lobecnc. Welcome to the Zone!
Originally Posted by lobecnc View Post
Hello,
On a lathe, the Z axis is the long, bed length screw. X is the short screw. Are you using the Syil Mach3 profile?
CR.
Old 09-09-2008, 05:55 PM
AH, OK, that may be the reason, I will swap them
Ah, OK, I had Z as the Short Ballscrew and X as the long (lead) ballscrew and if Syil tuned them differently, that would explain this.
Let me go try.
Old 09-09-2008, 07:41 PM
OK, a little further now, still need some help
Lathe is working well now for Z.
I had the cables swapped, Duh!, but while moving cables somehow I toasted the X driver board on the Syil C6 Lathe control box.
Do you happen to know the pinouts for the Y axis, they are set to 0 by default in the Syil profile. I want to set them in X so I do not need to create a new Mach3 screen.
There was absolutely no documentation for the system, zero, nada.
Basically because the lathe is only two AXIS, not three like my mill, I have a spare AXIS.
lobecnc
Old 09-10-2008, 06:19 AM
I was wrong about the spare AXIS
I guess Syil only ships the controller with two DRIVER boards for the C6 lathe.
I will have to replace the blown X axis. I checked the fuse, it is good.
Thanks for the help, I think I will be good now
Old 09-11-2008, 08:55 PM
Z working fine now
Z axis is perfect now with new coupler sent direct ship from Syil.
Those guys have excellent service at Syil America,
One quick question, does anybody get faster than 65IPM in RAPID on Z with Mach3 with the Syil C6 lathe.
Old 09-12-2008, 12:30 PM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Just a guess.
This is just a guess, but don't quote me.
I think you might be able to run 100 IPM.
Just push up the limits in Mach3 until it looses steps and back off about 30%.
Mariss Freimanis might suggest something other than 30%. He is the expert.
Old 09-12-2008, 12:48 PM
syil canada is on a distinguished road
i had the same problem with z axis, if you remove the the motor housing you will notice there is a plate that holds the bearing against the ball screw. we found this plate was creating a lot of pressure against the bearing and preventing it from moving freely, as when this plate was off the z axis moved freely.
We then took the plate off and faced off .015" and presto we now can run the it @120 imp. before we fixed it we also found that our repeatability was off.
hopefully this helps,
keith
Old 09-12-2008, 09:11 PM
Some information about the plate on the Ballscrew
Hi
Thanks for all the replies
What I did get from Syil was a new coupler which seemed to work better.
Seems to run smoothly at 65IPM.
Can you give some details on the ballscrew plate pressing on bearing, is this behind the large nut.
Laurence
Syil X4 cvafiadis Syil Products 1 05-24-2008 11:08 PM
Syil X7 dpaish Syil Products 0 03-21-2008 09:11 PM
Mach3 won't cut this file smoothly Salty72 Machines running Mach Software 2 11-21-2007 08:17 PM
Syil c6 in2steam Mini Lathe 5 03-27-2007 03:40 AM
Syil Q&A JBak Syil Products 7 11-19-2006 12:54 AM
