Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 08-22-2008, 09:11 PM
Involute is on a distinguished road
Need tips on SX3 disassembly
I can't separate the y-axis stepper from the saddle on my SX3. The Introduction doc says to remove the two bolts and push the saddle forward, but I can't get the saddle to move, or to separate from the stepper mounting plate. I have the table at full extension (away from the pillar). I've let some oil soak into the join between the mounting plate and the saddle, hoping it would loosen up the pins, and I can create a maybe .010" gap between the two by rocking the stepper, but I can't get the two pieces apart. I've also loosened all the y-axis gib screws.
Any tips?
Thanks.
Old 08-23-2008, 02:48 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hello,
If everything is lose perhaps a small pry bar or other suitable tool coul be used to persuade the stepper mounting plate to seperate. It may just be a tight fit on the dowels and it sometimes takes gentle prying at each end to get them apart. If the gap is very small I have even had good luck getting things started with a rigid putty knife, and then using a pry bar to finish up. Make sure all fasteners are remove and there is nothing holding it in place before trying to pry it apart. Just curious, but why do you need to seperate the parts to begin with? Modifications?
Regards,
Regards,
Wes
Old 08-23-2008, 03:04 AM
I managed to get it apart, but only by "gingerly" whacking the saddle with a small sledge hammer, creating a gap big enough to get a screwdriver into and then using that as a wedge. Now I'm having the same problem with the x-axis and so far it's not responding as well as the y, but it's late here (in California), so I'll try again tomorrow.
I need to disassemble the y-axis because the y ball screw nut disintegrated and I need to replace it. As for the x, I figured as long as the machine's apart anyway I might as well disassemble it, too, and inspect the ways, which I never did when I first got the machine since I couldn't get it (or the y) apart. If it remains uncooperative, I'll leave it. The machine's been working great for the last 18 months, until this (though I don't use it very often), and Syil America's been extremely helpful.
Involute
Old 08-23-2008, 12:26 PM
Old Megawatts is on a distinguished road
Taper Pins
I had the same problems with my machine. The folks who assembled these machines thought the pins were nails and tried to drive them all the way in. This makes them nearly impossible to seperate. Taper pins should be threaded on the large end with a nut so they can be removed. The better alternative is a straight pin.
OM
Old 08-23-2008, 12:49 PM
So, how'd you get your machine apart, OM? I'm thinking of either trying to sand down the pins, or drill out the holes, before putting it back together, so I don't have to go through this the next time. It's not clear to me what value they add over just the bolts. I know we don't want the steppers flopping around adding to backlash, but I would think the bolts would be enough to prevent that. Certainly snug (not "nailed") pins would be adequate.
Involute
Old 08-23-2008, 01:19 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
I don't have a Syil. Mine is a Grizzly SX3, with CNCFusion deluxe ballscrew kit. CNCF does not USE the taper pins in their conversion.
I found this Preparation Guide from Arc Euro Trade very helpful:
http://www.arceurotrade.co.uk/projec...on%20Guide.pdf
BTW: You have a fairly early SX3. These were notorious for having the quill DRO short out the whole spindle drive.
If you haven't done so already, I strongly advise that you IMMEDIATELY either remove that (ticking-time-bomb) Quill DRO, or insulate it from the PCB board behind it.
CR.
Old 08-23-2008, 02:08 PM
CR:
Regarding the DRO short, are you referring to what happened to this guy (and, I guess, others)?
Problem with syil x3 cnc control...
I haven't been able to find any other references.
Involute
Old 08-23-2008, 02:10 PM
Yep! That's the problem I was referring to. Better safe than sorry.
CR.
X3 Spindle Disassembly dneisler Benchtop Machines 11 08-16-2008 04:37 PM
SX3 disassembly trouble Involute Syil Products 2 04-22-2007 07:16 AM
anybody compare HT finecut tips to TD 1Torch tips for dross? Knut CNC Plasma and Waterjet Machines 0 09-29-2006 02:17 PM
Drafts: Tips for vendors and tips for RFQ writers... InspirationTool Employment Opportunity 3 12-20-2005 09:44 PM
disassembly of stepper motors dhprc2 General Electronics Discussion 8 06-25-2003 08:09 PM
