Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 08-07-2008, 11:04 AM
neilw20's Avatar
neilw20 is on a distinguished road
Smile Surface Grinding
Multi purpose now...
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 08-07-2008, 02:20 PM
iGG1e is on a distinguished road
Nice idea, what did the finish turn out like?
Old 08-07-2008, 07:19 PM
neilw20's Avatar
Smile The finish !
Really good. With Z steps of 0.25mm you could just see the line but in no way could I feel it. With a final measure on last pass on this job maintaining 0.01mm between parts and I stacking two parts and turning around parallel surfaces within 0.003mm as best I can measure. Job tolerance is +/-0.01mm
so I am happy with it. This was on CR12 stainless steel which is the stuff used for making knife blades in meat munching machines.
B1tch of a job to clean the machine afterwards. This gray gunk like all grinding machines seem to get. Need different coolant for grinding maybe.
Old 08-12-2008, 01:16 AM
neilw20's Avatar
Talking Magnetic Chuck.
This is working even better with a magnetic chuck. Pictures soon.
Old 08-12-2008, 01:28 AM
JPW JPW is offline
JPW is on a distinguished road
Please pardon my OT. Have you seen this before? Wondering what your thoughts might be about this drive.
http://www.nexengroup.com/nexen/index.jsp
Old 08-12-2008, 02:27 AM
neilw20's Avatar
Question Hmmm..
CNC made pinions without a gear hob. As long as the geometry on the rack matches it may be OK. Whether the geometry gives the perfect linearity possible with involute gears needs some analysis before committing to the way they drove windmills. I am not saying it won't work. Just make sure that the limits are within the tolerance of the application.
Tags
sx3 cnc grinding
Why is surface grinding so accurate... WilliamD General Metal Working Machines 11 07-22-2007 07:14 AM
Surface Grinding Woes Zumba General Metalwork Discussion 25 03-20-2007 11:37 PM
Surface Grinding Aluminum? kumaichi General Metalwork Discussion 8 10-31-2006 07:24 AM
Quote for surface grinding hoju1301 Employment Opportunity 11 09-06-2006 11:16 AM
Small, quick, surface grinding job... InspirationTool Employment Opportunity 3 03-15-2006 12:42 PM
