Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 07-27-2008, 08:46 AM
Martin Long is on a distinguished road
X4+ 4axis
How does one set up the 4th axis on a X4+?
All I can make it do is run around in circles.
Can some one assist?
Martin
Old 07-27-2008, 01:37 PM
neilw20's Avatar
neilw20 is on a distinguished road
Talking Stop it running.
It is probably running continuously because the limit switch is enabled for the A axis. When you REF the machine the axis starts rotating. You really don't need a limit switch, so disable in the config (pins etc..)
Now just JOG it around to zero using page-up/down and zero the DRO.
A45 now moves to 45 degrees. Depending on the config page settings A-5 or A355 may go the long way from here, or the short way. I like the short way.
I prefer to fit a 6 pin plug (with at least 5 amp contacts) on the 4th axis.
6 Pole JAYCAR IP67 multipole connector and socket is perfect. There is also a screw cap cover available.
It is VERY IMPORTANT that the power is off when plugging or unplugging 4th axis. A voltage spike can damage the driver and void your warranty.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 08-25-2008, 10:29 PM
4 axis plug
DSCN1407.pdf
Just a little reminder to switch off the power prior to conecting/dis-connecting the 4 Axis.
Martin
Martin
Old 08-26-2008, 04:45 AM
iGG1e is on a distinguished road
Hehe nice touch with the sign.
Thankfully I distrust machinery to the extent where I always switch it off before doing anything such as setting up the 4th axis. Even the spindle lock mechanism I did kicks in the emergency reset whilst it is engaged during a tool change. Hopefully a power draw bar will make that a thing of the past.
HELP! Need datasheet for aliencnc 4axis stepperboard glenngb Linear and Rotary Motion 2 06-17-2008 12:38 PM
Need some help please, datasheet Aliencnc 4axis board glenngb Controller Cards 3 03-25-2008 03:23 PM
4Axis Format G-code Example louis14 G-Code Programing 0 07-27-2006 12:15 AM
L297-8 and 4axis BOB aem_argentina Open Source Controller Boards 1 02-20-2006 10:55 AM
Cool picture of our 4axis Gujustud CNCzone Club House 14 01-24-2005 05:22 AM
