| Syil Products Discuss Syil milling machines and conversion kits here! |
I'm looking at making one the Auto Z Zero setting tools from here Another Aussie Auto Tool Zero Setter I had a look in the back of my X4 but I have no idea on where I can wire it up to (the thread says wire it into a spare input on the BOB). Can someone point me in the right direction? BTW, While I had the back off I installed the cover on some hinges so it's easier to work on. Plus I wired up a plug so I can disconnect the 4th Axis when not in use. |
| John. This type of setup uses the spindle/bit and the plate as a circuit. Not always the best idea. If you have a problem with use and it causes a fault you will most probably void the warranty. Better idea is to make a Z axis setter with a switch inside similar to the limit switch. I use this type of switch on our flat bed router to re-set the z after machining the spoilboard. Just utilize a redundant axis limit switch input. cheers Frans |
| Hi, The easy way to do this is without modifying your X4 would be to add a second parallel port to your P.C. and a inexpensive C10 BOB Then you would just assign the probe to the second lpt port and select the appropriate pin. Very simple solution and you will not void your warranty See attached link for BOB http://tinyurl.com/6gsngh PCI Parallel Port Card http://www.newegg.com/Product/Produc...82E16815166005 Hope this helps. Jeff... |
| Not as yet Martin. I have a BoB that I got from www.cnc4pc.com but that's as far as I've gotten. |
| I purchased a pendant from cnc4pc and adapted it to my SX3 using a second parallel port, then drilled a small hole for a small banana plug female conector and now Im using this setup : XYZ Probe modification Works like a charm! Also since I have a female plug I made a toolsetting plate for the C6 lathe ![]() Pablo Last edited by PEU; 08-18-2008 at 07:23 PM. Reason: typo |
#10
| John-t-h I would advise disconnecting the power to the 4th axis drive when that motor is disconnected. And most certainly do not disconnect the motor while powered up. Do you have a spare input on the BoB? Do you have PDF spec for it? Greg |
#12
| I was able to chase down a PDF on mine (older model) you should be able to do the same. Look at your "ports and pins" in Mach3. It will be obvious if you have any inputs spare. There are only five available. 10 - 13 and 15 Usually just looking at the BoB will give a good indication. Look for white printing on the board. Just as an example here is a pic of the older model taken from the PDF. Note the white printing. Greg |
| Connecting rod | ACME | I.C. Engines | 18 | 08-11-2007 01:09 PM |
| Connecting to Microscribe 3dx | robinsoncr | Digitizing and Laser Digitizing | 4 | 03-03-2007 02:26 PM |
| connecting two cnc routers to one pc | ctyler | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 02-23-2007 12:09 PM |
| connecting | KrashKing405 | Open Source Controller Boards | 18 | 07-26-2006 06:30 PM |
| Connecting Amp Enable | keithorr | CamSoft Products | 5 | 03-21-2005 06:31 PM |
