Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
  #13   Ban this user!
Old 07-24-2008, 09:46 PM
Journey_Man's Avatar
Journey_Man is on a distinguished road
Originally Posted by peu View Post
Today I visited the local representative of www.intorq.de company, they sell reduction gearboxes, brakes, etc. Im doing the homework for a turret like yours SANS the compressed air, after speaking a while with an engineer about doing it with gearboxes I asked: what if I use a brake?
He replied, its less expensive solution for sure, and suggested to take a look at these brakes: http://www.intorq.de/content/produkt...t.aspx?lang=en
I wonder if one of these can be used to hold the turret safe/firmly in place. What do you think?
Pablo
Hi Pablo, I think that a "sure lock up" would be the key. That is why my turret uses air to push the head out, rotate and return to the lock position. I used 8 1/4" dowell pins they fit nicely in .251 reamed holes when it is cycled shut. It will not move when it is in the closed position. Very simple. Bob
  #14   Ban this user!
Old 07-24-2008, 10:01 PM
cjdavis618 is on a distinguished road
I saw the other post where you said you found plans. Where did you happen to find them?
Chris
  #15   Ban this user!
Old 07-25-2008, 04:49 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Plans would be nice at least to get an idea on the mechanicals. Thanks.
I was initially just going to try and use an existing rotary table with a spring loaded hook as a catch with a switch on it, but after seeing this design, it might just be much better to build from scratch. I really like the idea of locking pins all around. Nice an solid there.
There are two issues I see with the braking idea. First is that it operates using an electromagnet. The second is the same. Shavings and chips would like to stick in any crevices in a magnetic solution. I think they stick just fine without the help of a magnet.
If the magnet lost power, the tool engaged would just spin and the next tool might spin around and engage or rather crash. Not pretty.
The air cylinder type if it lost air would still be solid and locked. That safety alone makes this more appealing to me.
Lee
  #16   Ban this user!
Old 08-02-2008, 11:50 AM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
I kept thinking about this brake issue and I think a clutch should be a better option, but not a disc clutch, one with a coupling, like this one: (from http://cnc-projects.de/)
I have this question regarding your turret Bob, what is its external diameter? I mean, after you add turning tools they add something like an inch more to its radius and this would limit the diameter of the pieces you can turn on the C6, right?
Please post more photos, details !!!
Pablo
  #17   Ban this user!
Old 08-02-2008, 01:05 PM
Hey Pablo,
I only have Photos of the assembled Turret...I origionally found some drawings on the internet. and I designed the rest to fit the C6. The origional Turret head was 7.25"odX1.75thick...I scaled it to 5.0x1.25thick.The Cylinder was 6.5x4.25 with a bore of 4.0. I scaled it to 4.5 with 3.125 bore X3.5 long. There are alot of pieces to be made. I had to make everything around the Head and Cylinder. The Base has a radial bore in it to nest the Cylinder in . everything had to be on a 3.0" C/L in order for all 8 tools to be rite. Bob
  #18   Ban this user!
Old 08-04-2008, 11:19 AM
PEU's Avatar
PEU PEU is offline
Hi Bob,
As you suggested, Im thinking towards the dowel pins, but I never designed a device using them, I have a couple of questions:
1) how do you prevent movement in the tool plate when the dowel pins are engaged? I mean if they fit too snugly they may be difficult to remove but if you leave the receiver holes too wide you have backslash, this makes the next question obvious: 2) how do you prevent the dowel pins to get locked?
Is there any reference where I can learn more about the dowel pins? Im googling but found no good tutorials.
Thanks!
Pablo
  #19   Ban this user!
Old 08-04-2008, 07:59 PM
antichip is on a distinguished road
to have any type of positive lock the pins are a must. there are 8 of them so it should help to balance out the error. But there prolly should be more than a couple tenths out of round for the hole pattern itself. The dowel hole would then be reamed to size for a press fit ? A couple tenths over sized would be the tolerances I would hold on the hole sizes for the mate. I would then pray as I added pin by pin testing all locations.
  #20   Ban this user!
Old 08-04-2008, 08:46 PM
Dowell Pins
Hey Pablo;
Here is a Link for you;http://www.efunda.com/processes/mach...drill_ream.cfm
The Dowells in the Turret are Pilot drilled through the cylinder(.125) Then Reamed .2497 & pressed in from the front side. (the pilot holes are for removing the pins.)The holes in the Turret Head are.251....I made a fixture plate with the same bolt circle to hold the Turret head in order to mill .500 slots and bore .625 holes for drills/bars ect. everything is within .001. It has to be in order for the whole thing to come together. Bob
New TL-2 Pictures! AMCTony Haas Mills 10 12-12-2006 09:47 PM
Bolt on Turret 'v' VDI Turret scappini General Metalwork Discussion 0 07-20-2006 06:59 AM
MTC Pictures MikeT DIY-CNC Router Table Machines 4 10-15-2003 01:02 PM
Pictures JIMMY DIY-CNC Router Table Machines 3 07-18-2003 02:23 PM
Pictures Turbine CNCzone Club House 0 07-11-2003 09:49 PM
