Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 07-19-2008, 05:31 PM
Gregory_C is on a distinguished road
I finally made something
Ok so i blow chucks at math, but its a start
[IMG][/IMG]
[IMG][/IMG]
Old 07-19-2008, 05:39 PM
teamtexas's Avatar
teamtexas is on a distinguished road
Way to make something.....what is it?
Dan
Old 07-19-2008, 05:42 PM
It is a fixture that will hold pieces of Ti at 3/8 diameter. That way i can machine 7 pieces at once instead of doing it one at a time. They will hopefully end up as a micro dermal for body piercing.
Old 07-19-2008, 07:10 PM
syil canada is on a distinguished road
its about time :)
just joking, good job for your first CNC project!
Old 07-19-2008, 07:36 PM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
Looks good,
Make sure all the pieces are tight before running, and pull out any that are loose or you'll get a oops moment. I've had that happen before... one piece just small enough that the jaws didn't hold it tight enough, and when the cutter hit it....... oops
Cheers,
Jack
Walking is highly over-rated
Old 07-19-2008, 09:06 PM
ironDigit is on a distinguished road
to prevent any oopses you might want to mill a keyway right true the middle of the fixture.That will make sure the vice is gripping the workpieces instead of itself and having your work spin fly damage or break your cutter.
seven to 1 !now that's improvement ,so keep up the progress !!
good lukk.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 07-19-2008, 11:20 PM
john_t_h's Avatar
john_t_h is on a distinguished road
How did you do it Greg? Did you design it in CAD and then generate the G Code through a CAM package?
Now your mill is dirty
Finally! MrWild LinuxCNC (formerly EMC2) 2 05-12-2007 08:42 PM
Finally!!!!!!!! Cyclone DIY-CNC Router Table Machines 4 01-23-2006 01:17 PM
Made in Australia (Made in taiwan, china) carbidecraters General Metalwork Discussion 0 01-10-2006 03:05 PM
PCB. finally, oh finally MrWild General Electronics Discussion 9 12-13-2005 08:37 PM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 06:54 PM
