| Syil Products Discuss Syil milling machines and conversion kits here! |
We are thinking of purchasing the Syil C6 cnc lathe for producing small wooden components (from 15mm to 75mm in diameter) in batches of 10 - 50 at a time. Has anyone had experience of this machine for wood turning? Is any special tooling required? Is the machine reliable? The price is attractive and we dont need the capacity of higher volume, more expensive machines Thanks Hilary |
| For off the shelf sharp inserts, the ones designed for aluminum have lots of top rake and work well on wood. The sawdust will sure soak up the oil on the screws and slides. Make sure you oil it daily. Teflon stuff on the slides is great. You need to add oil at the ball nut to do it properly. Just putting it on the screw is not so good. |
| Nielw2Sorry for the delay in replying.Thanks for the advice we have bitten the bullit and it should be here shortly.Conquering Mach3 will be the first issue and then looking at different tooling after that.I dont see many postings on people using small engineering lathes for wood am I missing something? |
| Utilization and enjoyment is what life is all about. Google Turners Cube. Some of those made out of wood would be quick, neat and easy. SX3 and X4+ is big enough to make real Ultralight Aircraft Propellers. Make lots of dust, but cleaning up sucks.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
| Tags |
| cnc, lathe, syil, woodworking |
| Need Advice purchasing cnc mill.. syil X3 or tormach? | petecul | Benchtop Machines | 3 | 04-13-2007 06:37 PM |
| Combining woodworking with CNC | Patrick2by4 | WoodWorking | 47 | 10-29-2006 07:44 PM |
| Syil(Advice and Suggestions Inbox) | syil | Syil Products | 24 | 10-25-2006 11:37 AM |
| My Sherline CNC for woodworking | bobbyzr7 | WoodWorking | 10 | 06-20-2006 11:24 PM |
| Using onecnc xp for woodworking ? | RandMan | OneCNC | 16 | 02-04-2004 04:23 PM |
