| Syil Products Discuss Syil milling machines and conversion kits here! |
i have spent the last 3 weeks making bits and getting ready for the "big switch on" and nothing happens! so here i am asking you lads out there for some advice, mach 3 is loaded onto a pc with a new hard drive (nothing else on it) the dro positions move when i jog from the keyboard but no axis movement.on the "box" the following lights are ON signals2,Adir,Aclk,Zclk,Xclk,Yclk is flickering,limit switch Z REF,X REF.Also where do you plug the spindle encoder into there is only the Y axis plug that it will fit, is this right in here? i have saved the c6 profile to a usb stick but i cant upload it to the mach.I know this is a lot of info but i am beginning to wonder is it me or should this sort of info come with the machine???Anyway just going to bang my head against a brick wall!! even a bit of a lead to any of these questions will keep my spirits up thanks. wilko1. |
Hi I have an X4 and not a C6 so no specific info for you - however I did discover the way to upload the profile is to save it in the Mach 3 folder on you PC. Then when opening Mach 3 open the Mach 3 loader icon (not Mach 3 Lathe or Mach 3 Mill). The Mach 3 loader should then see all your profiles saved in the Mach folder and you should be able to pick it from the list. Hope that helps a bit anyway. |
| Hi, You may need to check the control box and make sure all the wires are connected. I received my SX3 with several wires disconnected and basically had no movement from the steppers. I agree with you that a diagram of all the basic wiring connections should be included with the machine and a basic operators manual is so common place nowdays it's hard to believe it would not be included! I don't have the C6 yet but there are several users here on the Zone that do have the C6 so hopefully they will reply. Regards,
__________________ Regards, Wes |
| Trouble | extreme | DIY-CNC Router Table Machines | 36 | 07-11-2010 05:14 PM |
| Problem- TL 1 trouble | WOB729 | Haas Lathes | 3 | 05-07-2008 08:27 AM |
| 100 in/min X, Y, Z with IH CNC Kit. Any Trouble?? | haysys | Industrial Hobbies (Support forum) | 10 | 02-01-2007 09:24 PM |
| More PIC trouble | robe_uk | PicStep Controllers | 5 | 10-10-2006 04:13 PM |
| having trouble getting this to cut right | MIKENLN | BobCad-Cam | 2 | 04-19-2005 03:24 AM |
