Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 06-23-2008, 04:57 PM
adam666 is on a distinguished road
SX3CNC Help
Im looking at purchasing an SX3 / SX3CNC but have a few questions....
SX3CNC = $~$8000nz
SX3 : $3000nz
Syil CNC kit: $4000nz
Are there any other kits available for conversion of an SX3? better or worse than syil kit?
I dont mind the fact Ill may need to make / adapt parts when fitting kit but what options are there??
Anything else I should be aware of with the SX3? From the threads ive found there were a few issues when released a few years back but sounds they have been sorted by Syil on all recently purchased units?
Adam
Old 06-25-2008, 03:19 AM
ToolMach_Aust is on a distinguished road
Adam.
My recommendation is not to purchase an SX3 as Sieg still have problems with the electronics.... the issue is they are only really designed for 110v. As soon as you put 240v it can and often does cause problems...
We stopped selling the SX3 as the failure rate was over 60%...
The problem with the SX3 was NOT due to the Syil conversions.... the Syil conversions have been great... no stepper or driver failures at all. It was and is the Sieg electronics.
The new X4Plus is far superior to the SX3.... better electrics.. designed as CNC and not a conversion, faster rapids, one shot oiling etc, etc...
You should be able to purchase the X4Plus for around the NZ$7000..
The prices you quoted sounded awfully high?... where from?.
cheers
Frans
Old 06-25-2008, 02:04 PM
Hi Frans,
Prices quoted are form Brian @ mtm tools (micro tech machines palmy)
I have adjusted to include GST
The X4Plus looks a very nice machine, is there any way to have some sort of manual control over it? without needing all your jobs done in CAD?
this is my main reason for considering the SX3
real time control via software? like small box with knobs which control x,y,z would be nice.
cheers
Adam
Old 06-25-2008, 02:14 PM
daedalus is on a distinguished road
you can get pendants with manual pulse generators, these are little wheels with encoders on them that allow you to manually move each axis. This is supported in mach (machine control software), and there are several manufacturers of pendants, or DIY details on this forum. Also mach has support for quick on-screen macros for doing simple tasks without resorting to CAM.
Old 06-25-2008, 02:58 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Tom Caudle at CandC N C.com (remove the spaces) has a very nice JOYSTICK (or a wheel one if that's what you want.) pendant for less than $200.
CR.
Old 06-25-2008, 06:26 PM
Adam.
The X4Plus comes with a Hand Held MPG which can be used without the computer being switched on... The MPG is great.. you can do all of your jogging, machining, setup using the MPG alone.
Check with Brian at mtm tools I am sure he is getting some X4Plus machines.
If Brian cannot help you we can send to NZ...
cheers
Frans
ToolMach
Originally Posted by adam666 View Post
Hi Frans,
cheers
Adam
Old 06-25-2008, 09:24 PM
Awesome!
Does look like a much more capable machine!!
Can you PM me with details re: Purchase cost (including 4th axis + keyless chuck), shipping costs (Wellington, NZ). Ill check with Brian also but would like something to compare with.
Thanks alot!
Adam
Old 06-25-2008, 09:41 PM
Adam.
Brian mtmtools are the NZ distributors and we do not want to encroach on their territory.
Please contact Brian first and if he cannot help then we will discuss with Brian if we can assist you.
Please contact us at info@toolmach.com.au
Awesome!
Thanks alot!
Adam
Old 06-25-2008, 09:58 PM
oh of course!
Have requested pricing from brian today
Thanks for your help!
Adam
