Cool!! Is the MPG available seperately?
We designed a custom cable that attachs to an unmodified Syil X4+ MPG via a DB15 male connector and to the PC via a DB25+USB.
Whats the point of it? You can use the MPG and not lose the references and softlimits.
Of course, the MPG can be used with any machine, for example I used it with a SX3
Here is a video I just made:
"http://video.google.com/videoplay?docid=662177008976443556&hl=en"]Mach3 via Syil X4+ MPG remote
Hope you all like it
Pablo
Regards,
Wes
So using the mpg as it comes standard in the X4 won't interface with Mach3???
Do you have a wiring diagram for the cable?
Was any drivers or software configuration needed?
Here is the Schematic, no drivers necessary, you just need to add a new parallel port and configure OEM triggers and their OEM codes.
I have the OEM configs at the office, on monday I will post how to set it up.
I can make a small run of cables if there is enough interest![]()
I purchased an extra one from CNC4PC: http://www.cnc4pc.com/Store/osc/prod...roducts_id=160 they sell it with a DB25 connector already wired and setup files to make our lives easier, if you dont have a X4+ this is what you need
Arturo is a great guy to deal with and his service is top notch!
I will receive mine next week, will post comments.
well done Pablo, I think it'll only be a matter of time before people begin to realise how useful this will be. Any chance you could post the OEM codes and brief setup description?
Sorry for the delay, we ran out of X4+ (more coming in a few weeks) I went to one of our customers to install this mod and made the full tutorial.
We're selling to our local customers the ready made cable+parallel port+installation for $70
Here are the screen captures, they are self explanatory:
Open in Windows device manager the installed parallel port and look for its I/O Range
Enter this value as shown for port2 and check the enable 2-9pins as input
verify that you have mach set up as shown
Configure pins
Configure System hotkeys to use the OEM triggers
Configure MPG, the values will be different, you need to calibrate all 3
In general config verify the highlighted values
Attached is the ready made XML.
Good luck, and if you need this custom cable sent to you, just send me a PM to arrange the $$ details
Pablo
Wow guys, I tought I would receive a couple of requests in the next months, and I received 4 already
Not that Im complaining, but since these cables take a couple of hours to be made I decided to sketch a quick and dirty PCB to speed things up a little. You will laught at my PCB design abilities, but in this case cosmetics is not as important as a job properly done, and besides this, you won't see it because it will be under isolation
So please give me a few days (no more than a week) to have them done, I have a local shop with very fast tournaround times.
BTW, I can receive payment by paypal (cash or cc) and I ship via registered mail, the shipping cost is $8
Thanks!
Pablo
I will try making the PCBs myself:
Never did a double layer, but Im willing to try
Will report on monday
Today I finished the prototype, it wasn't as easy as I initially tought, but it was a really nice learning experience, also I made a small tooling plate that Im sure will come handy in the future:
Pattern is every 10mm one threaded 1/8" one not, the only holes that pass thru are the one adjacent to the long sides
Will try to make the remaining requested units tomorrow, if time allows. Thanks for the patience.
Pablo
slowly advancing, thanks for the patience:
Pablo
Pablo, no rush at this end. I would rather have it right then fast. We all appreciate your taking the initiative on this.
Rgerds, len
