Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 06-07-2008, 05:20 AM
Rainman229 is on a distinguished road
x3 and atc question
What pins do i have available on a sx3 to activate a relay? Or would going with a second port be a better idea?
http://www.rainman229.com
Old 06-12-2008, 02:11 PM
I guess no one knows
Old 06-13-2008, 09:16 AM
neilw20's Avatar
neilw20 is on a distinguished road
Smile 2 relays.
There are 2 relays, that can be setup as output #1 & #2 in Mach3.
Normally these are turned on by M7 (oil mist) and M8 (coolant).
M9 or M30 turns both off.
The relays are on the Spindle Control PCB rev 1.2 & rev 1.3. There is 1 common terminal and 2 free contacts marked S1 and S2.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 06-18-2008, 02:20 PM
Thanks for the info.
