Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 05-19-2008, 02:50 PM
rickturner646 is on a distinguished road
Problems getting X4 up and running
If anybody out there has gotten an X4 mill up and running with Mach3, do you mind sending me your mach3 config file?
I'm having real problems getting my new machine up and running and I'm tearing my hair out. The machine works fine in manual mode, and in CNC mode as long as I use the 'software MPG' built into Mach3.
However, I cant get the machine to move under program control. Behind that, I cant get axis references working, nor can I get the spindle to turn on under program control, nor can I get the 4th axis to rotate.
Driving me nuts, to put it mildly.
Any/all help and suggestions appreciated!
Rick
Old 05-19-2008, 03:43 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Please give specs and type of computer you are using.
CR.
Old 05-19-2008, 04:55 PM
gn3dr is on a distinguished road
Hi Rick
Sounds similar to a problem I had with mine. I could use the machine in manual but not under Mach 3 control.
Firstly have you set your charge pump output to pin 9 in the outputs screen of ports and pins?
The coolant output is pin 3.
It was not obvious (to me) but when the machine is under PC control there should be a little PC symbol on the bottom of the X4 display. And also when under Mach 3 control the manual / CNC button on the X4 has both LEDs lit (green and red)
If these display conditions are not there then it is probably the charge pump signal missing.
Under Mach control I could not move any axis or spindle but when I turned on coolant from the PC, the coolant button did switch its LEDS. However what I later discovered is that I should also have heard the coolant relay turn on.
When I had the problem I read the manual again and while not very clear - in the section which shows the interface board - it shows a little pot which needs to be adjusted to let the board see the charge pump current.
What I did was turned on the coolant relay from Mach 3 - then carefully turned the pot until I heard the coolant relay click on. (For what it is worth I had to turn the pot about 1 rev clockwise) After that everything worked under Mach control. (It was only at this point that I saw the little PC symbol for the first time on the X4 display.
Try this - hopefully that is your issue.
I asked Syil for the X4 Mach 3 profile and they e-mailed it to me.
Old 05-20-2008, 05:01 AM
Hi folks, thanks for the replies.
Crevice Reamer: the PC is a fairly substantial one - small desktop with a dual core 3.2 GHz P4 chip, 2GB of RAM and oodles of disk. Running XP Pro as I didnt want to have to deal with the additional complications of Vista. It seems well capable of running Mach3 - the interrupt iteration timer is constantly down at about 3 microsecs so there are probably no problems there.
Gn3dr: thanks for the info. I will try the charge pump signal change you mentioned. Might be that - both red and green lights are on but I didnt see a little PC symbol. I dont have a coolant pump hooked up (yet) so it is unlikely to be that. I figured that I would get to the point where I could dry-run a simple program without tooling / coolant / etc before moving on from there.
I am a bit baffled as to why I can move the machine under 'manual CNC control' using the Mach3 MPG, but not from a Mach program.
I have begun to wonder if it might be a problem around homing / limit switches / axis referencing. Where have you guys set your 'home' position to? I assume that the default is 'top left, z axis up' which would match the + axis directions that are set under X4 manual control. Thoughts?
Regards,
Rick
Old 05-20-2008, 07:43 AM
Originally Posted by rickturner646 View Post
Crevice Reamer: the PC is a fairly substantial one - small desktop with a dual core 3.2 GHz P4 chip, 2GB of RAM and oodles of disk. Running XP Pro as I didnt want to have to deal with the additional complications of Vista. It seems well capable of running Mach3 - the interrupt iteration timer is constantly down at about 3 microsecs so there are probably no problems there.Rick
Laptops and newer computers only send 3.5 volts through parallel port instead of 5 volts. You might want to check yours.
CR.
Old 05-20-2008, 12:09 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question Can't remember.
I can't remember if a program will run before you have run a reference cycle.
For a reference cycle to complete the limit switch settings have to make sense, be configured and work.
I always run a reference cycle when I turn on everything so that's why I'm not sure.
It makes sense to have to run a reference cycle, otherwise the program does not know the limits and can crash or damage an axis against hard stops.
You may be able to run a program if you turn off soft limits on screen 1.
Use the diagnostics screen to get all of the limit switches working.
You can use the MPG you say.
Will the PC keyboard arrow keys work? You must have jog enabled for this to work. Ctrl or Alt J I think from screen 1 or 2.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 05-22-2008, 11:46 AM
LEN1042 is on a distinguished road
CR.
CR, how do you go about upgrading the paralel port to get back to 5V?
Len
Old 05-22-2008, 12:25 PM
Hi All,
finally gotten the problems mostly solved, thanks to help from this forum and from the folks at Syil.
The main problems turned out to be (i) the charge pump being misconfigured (wrong pin), (ii) ditto for spindle control, and (iii) I had to change the Mach3 kernel speed from the default 25 kHz up to 45. Then I had to fiddle around with the homing options, but finally..... IT WORKS!!!!
Only one problem now - if I command the machine to move say 10mm along the x or y axis, the Mach DRO will say '10mm' but the machine physically moves 25mm. This 'multiple' of 2-1/2 times is consistent, but I cannot figure out why......
I have the machine set up for 1000 steps per unit (mm in my case) and that seems to be the right value. There are 200 steps per rev on the motors, a screw pitch of 5.08tpi (ie, 5mm per rev), and according to Syil, 25 microsteps per step. So, 200 * 25 / 5 = 1000 steps per mm.
If anybody has any ideas, I'd appreciate suggestions....
Rick
Old 05-22-2008, 04:40 PM
jalessi's Avatar
jalessi is on a distinguished road
Is the stepper driver set for 1/4 micro step?
Rick,
Try changing Mach III to 4000 steps per mm
Jeff...
Old 05-22-2008, 06:07 PM
acondit's Avatar
acondit is on a distinguished road
Hi All,
Rick
Actually it sounds like the drivers might be set for 10 microsteps / step rather than 25 microsteps / step. Can you check the actual settings on the drives?
Alan
http://www.alansmachineworks.com
  #11   Ban this user!
Old 05-22-2008, 08:34 PM
Len
Hi Len! This thread talks about how to add your own 5 volt supply:
http://www.cnczone.com/forums/showthread.php?t=14943
Also, some of the better breakout boards like CandCNC or Cnc4PC have built in 5 volt power supplies for this reason.
CR.
  #12   Ban this user!
Old 05-22-2008, 08:49 PM
Martin Long is on a distinguished road
Worried
You guys have me really worried, I have a X4+ being loaded onto a ship as I type this.
I'm really new to CNC and if faced with problems such as these I fear my machine will be idle more than it will be running.
Has anyone got a manual for this machine which can be emailed to me, this will give me a head start prior to receiving the shippment, or it may confuse me even further? I read in a thread that someone downloaded a manual from a website but did not specify the link.
Martin
Martin
HELP CNC Still Not Running Mr.Chips Machine Problems, Solutions , Wireless DNC, serial port 9 06-24-2007 08:49 AM
Running hot, really, really hot imagineer Stepper Motors and Drives 10 01-18-2007 08:51 AM
New X2 up and running mjarus Benchtop Machines 3 01-03-2006 07:41 AM
Problems running G-code milgo Mach Software (ArtSoft software) 4 10-31-2004 10:27 AM
running direction problems gv71 Yeager Automation 1 10-27-2004 07:19 AM
