Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 05-01-2008, 04:29 PM
oldtool is on a distinguished road
Steppers just growl
I am attempting to fire up a SX3 which I have ( Trying to ) converted to CNC using a Syil kit. The mechanics are complete and work well. I am trying to get the steppers running smooth using Mach3 trial software. It dos'nt matter where I have the Acc/VEL sliders the motors turn in growling steps or vibrate fierce. I have tried a few metric profiles with the same result even tried running the motors on the bench. I am using 1.7ghz from XP desktop. I will admit I am at at disadvantage electrically (Dum). So I need some help please.
Old 05-01-2008, 05:11 PM
wombat is on a distinguished road
Are you sure you wired your motors right? How many wires do you have?
Old 05-01-2008, 06:54 PM
Pretty sure wombat. Syil US sent me the wiring setup. xy have 4 and Z 8. I have tried just focusing on the Y at present. The problem however is common to xyz and all react with the same problem.
Old 05-02-2008, 12:45 PM
neilw20's Avatar
neilw20 is on a distinguished road
too thirds of May....
hi..
In Mach3 please go to the ports and pins (second on dropdown I think), second tab, and hit your Print screen button.
Open a word document and paste screen image using ctrl-v.
Send me the doc file meckelec@y7mail.com and I will look at settings for you.
Include in the email your setup file you are using. Please put in a zip file.
Old 05-02-2008, 06:22 PM
Ok Neil, done
Old 05-03-2008, 12:23 AM
neilw20's Avatar
Exclamation Your setup looks OK.
Peter.
I have emailed you my setup file, with some notes. Try it.
It is quite stable and has been used for a few months on many jobs now.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Where to get steppers legomanww Stepper Motors and Drives 10 06-08-2007 01:46 AM
X3 Steppers dneisler Benchtop Machines 0 04-23-2007 02:27 PM
yang growl BAD DOG Machine Problems, Solutions , Wireless DNC, serial port 1 02-16-2007 02:11 PM
Are these steppers ok? ghettoblaster Mechanical Calculations/Engineering Design 3 09-25-2006 12:03 PM
