Results 1 to 6 of 6
Thread: Add a Hinge to your Electronics Enclosure on your Syil X3 CNC Mill
    Apr 2007
    Hi All,
    I have had to access the electronics inside the enclosure on the rear of my cnc mill on numerous occasions. This generally meant supporting the electronics enclosure with twine whilst work was carried out inside the enclosure.
    Recently I had a young bloke helping me and I asked him to hold the enclosure whilst I tied it up with twine.
    He said to me " You silly old bastard, why don't you fit a hinge?" I had to admit that my method was indeed silly.
    I had in my possession an old brass piano hinge that was a perfect length for the task.
    The photos tell the story.
    www.cjh.com.au/hinge1.jpg
    www.cjh.com.au/hinge2.jpg
    www.cjh.com.au/hinge3.jpg
    Regards
    Chrisjh
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Yes the hinge does seem like a simple but much more effective way to attach the rear panel. I have not had many occasions to take mine off but today the Z axis stopped moveing when I was lubing the ways. Does not sound like the stepper is powering when I try to jog it so I guess I will be removing the rear panel or more sometime today or tomorrow. Do you by any chance know if there are any breakers or fuses for the Z stepper motor that could cause it to do this? Perhaps I will implement a hinge when I get the Z axis fixed.
    Regards
    Regards,
    Wes
    Apr 2007
    Wes,
    If X and Y are moving, then the 48Volt DC Power Supply is OK.
    Check the "bootlace" ferrules fitted to the ends of the wires enetering the green plugs to the Z Axis driver module. At the same time check the X, Y and 4th axis plugs (if fitted). These were not crimped properly in the factory and can come out fairly easily. A gentle pull on each wire in turn will reveal any suspect crimping.
    I got rid of the bootlace ferrules on mine and opted for tinning each wire with solder.
    There is nothing wrong with bootlace ferrules, I think that they are a great idea if fitted properly with the correct tooling.
    Regards
    Chrisjh
    May 2006
    I did the same with mine. Makes access a lot simpler.
    Greg
    Registered neilw20's Avatar
    Jun 2007
    Talking Mine hinged too.
    I hinged mine in a similar manner, and added a soft rubber dust flap at the top to stop shavings attacking th power supply.
    Was a good opportunity to add a power plug for the pump, the light and the 4th axis.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Registered rogerx3's Avatar
    Oct 2007
    England
    Hello Chrisjh
    My mill is in a corner of my spare room and yes I cable tie the case open, reaching it by crawling on my hands and knees under the rhs of my table and 3d arm. On arrival I usualy find i've left the cable ties behind - So I'm going to follow your lead as well and fit a hinge.
    My back and I thankyou.
    I dont know what I have made, but the swaf is shiny.
    1. Electronics Enclosure Sources?
      By Chris64 in forum General Electronics Discussion
      Last Post: 12-20-2007, 01:12 AM
    2. Electrical/Electronics Enclosure
      By audioandy1762 in forum DIY CNC Router Table Machines
      Last Post: 02-27-2007, 07:32 AM
    3. Not sure what to do about electronics enclosure
      By phantomcow2 in forum Benchtop Machines
      Last Post: 02-08-2007, 11:29 AM
    4. Hinge/Latch hardware (OT?)
      By Rance in forum WoodWorking
      Last Post: 01-03-2007, 08:25 PM
    5. Electronics Enclosure Box
      By JavaDog in forum General Electronics Discussion
      Last Post: 04-21-2005, 09:00 PM
