| Syil Products Discuss Syil milling machines and conversion kits here! |
Just got my X3 a few days ago, and I can't help but notice the stepper motors run real hot-like can't touch them at all. Is this totally normal?? I was thinking of some small CPU fans to help cool them, or would I be wasting my time. Great machine btw! |
| Hello, In general stepper motors can run a predefined level above the ambient temperature. This can easily get hot enough to burn you. The best way to be certain is to check a data sheet or contact the manufacturer, measure your motor temp and compare. I used a meat thermometer to measure mine though it was probably somewhat hotter. Also it might be a god Idea to run your motors at less than their rated amperage(80%?). You should see a marked drop in temperature with only a little drop in performance. Better safe than Motorless. Chuck |
| I use hobby CNC driver hardware and thats where I set the motor current with a small potentiometer. I don't own a X3 though so I cant be much help. I run a homemade setup. The current control is definitely a hardware setting somewhere. |
no not a mach3 setting, by adjusting your amperage on the stepper driver at holding tourque, using a multi meter in series.
__________________ I dont know what I have made, but the swaf is shiny. |
| You can also enable "auto 1/2 current" (s1). I like to keep my electronics cool. For the X & Y axis I mounted a P4 heatsink onto the stepper. The entire power supply, stepper box have also been relocated into a server HD storage tower. It's great. 3 mini fans cooling each stepper controller and plenty of space for the power supply and I/F board. |
What exactly is a P4 heatsink?? I was thinking of wrapping the motors with 1/4 copper tube and making a liquid cooling system with a pump. Is this a ridiculous idea? |
#10
Before any thing else check the running amperage of your stepper motors, and adjust them via your stepper drivers. Only then consider additional cooling methods, after all its not like you're overclocking a CPU.
#12
| hi hodge98ws6 this link should help with your stepper motor adjustment http://www.cnczone.com/forums/showpo...23&postcount=7 it did with mine.
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
| stepper motors or servo motors? | jprobst | Torchmate | 3 | 07-13-2007 05:37 PM |
| New Stepper motors. | alexccmeister | Stepper Motors and Drives | 4 | 04-08-2007 07:53 AM |
| Q on stepper motors | wood_Workur | Benchtop Machines | 4 | 10-05-2006 03:05 AM |
| Stepper motors in the UK. | Kammo1 | Stepper Motors and Drives | 0 | 07-05-2005 04:29 PM |
