Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 04-07-2008, 11:23 AM
Bugster is on a distinguished road
My x4, It`s here!
I just opened a can of Syil x4!
It is outside right now, plan on getting it down to the basement during the evening.
It looks to be the first one in the word!?
At least it is the first one in Norway!
Anny advice on getting it a few kilos lighter for the big down the stairs scenario?
Did a cowardly atemt to take off the table, but i wimped out, beeing scared to f**k something up.
TNT has lost the shipment of papers from syil somewhere, so I dont have the manuals yet.
Old 04-07-2008, 05:10 PM
john_t_h's Avatar
john_t_h is on a distinguished road
Don't tease us.... give us some photos!!!
Old 04-07-2008, 06:36 PM
rogerx3's Avatar
rogerx3 is on a distinguished road
Yew lucky luck bugster!
I have a super x3 with 4th axis and I live in a flat may I sugest some pointers?.
If you are going to manualy carry it down - strip it into peices and make a wiring diagram, take your time and double check. I did and had no problems, you are going to have to any way to clean and possibly lap the ways. also if possible get a friend to help I did'nt it is possible to reassemble on the stand, hard but possible but then I'm stupid.
good luck you lucky man.
roger x3 (should be roger sx3 ha ha)
I dont know what I have made, but the swaf is shiny.
Old 04-08-2008, 03:01 AM
I will post some pics soon, just need to get it down first.
I found a "getting started" manual on the web, and have now taken the table off.
Will try to move it later today.
Will there be a lot of wireing trouble to take the complete head off?
Old 04-08-2008, 03:07 AM
iGG1e is on a distinguished road
Sounds like you've got a nice challenge on your hands. I'd say this was the perfect opportunity to take it apart if you need to do it to ease moving as this will allow you to clean/inspect it.
It's always nice to have a manual, but I doubt you'll be missing that much. Taking loads of pictures whilst dismantling and unplugging is your best bet to putting back together successfully. It'd be quite nice to see how its constructed
Old 04-08-2008, 03:39 PM
GTC GTC is offline
GTC is on a distinguished road
pics! pics!
Old 04-13-2008, 12:16 PM
tmarks11 is on a distinguished road
How is the fit and finish?
Is it better then the pcitures on the Syil Canada website (they show overspray of yellow paint on the spindle, ways, etc... looks like someone just slopped on the paint after assembly without bothering to make much effort at masking).
pictures, pictures, pictures...
Old 04-13-2008, 03:56 PM
LN-JET is on a distinguished road
He must have fallen down the stairs...
Old 04-14-2008, 08:32 PM
Martin Long is on a distinguished road
Cool Camera
Can someone loan him a digital camera? I can't wait any longer!!!!!
Martin
Old 04-14-2008, 10:39 PM
neilw20's Avatar
neilw20 is on a distinguished road
Talking I wish.
I want his lubrication system.
If the back is anything like the X3, while you have the back off, install a piano hinge on the side where all the wiring is and put a power receptacle on the other side for the pump and a light.
I use a magnetic lamp as a power indicator.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  #11   Ban this user!
Old 04-14-2008, 11:28 PM
Hi guys :-)
Sorry I havent posted anny pictures yet.
I have just assembled the stuff I stipped it of.
I promise to post pics later today.
Annybody with suggestions on how to adjust the gibs right?
  #12   Ban this user!
Old 04-14-2008, 11:40 PM
neilw20's Avatar
Lightbulb Use a dial indicator.
Get them as tight as practical without stalling the steppers.
You should be able to get them within 0.02mm if all is parallel.
For X and y, keep rapiding backwards and forwards at 2500mm/min and tighten until the steppers skip steps, then back off a bit.
Use 1500 in Z. The gas strut (if the SX4 has one) needs to be about 45kg
my factory one was 60KG which is much too high.
The 60KG causes the Z axis to bounce around instead of sitting firmly on the ball screw. This gives irregular machining marks.
