Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: No response from my Syil Super X3
    Feb 2008
    I have these items:
    Syil Super X3 CNC
    Bobcad cam
    mach 3
    The issue I am having is when I use the Mach 3 with the Mill. It does not respond to any inputs. No G-code makes any movements on any axis. The mill is on, and is on CNC mode. I have an IBM thinkpad that I use for both programs, this shouldnt be the issue. Has anyone run into this problem?
    I really need to get this thing milling stuff asap!
    Note: mill has never milled anything out, its still brand new. When the mill came, there was the circuit board laying on the milling surface. I took the back plate off and installed the circuit board onto the back of the mill. Maybe there are items there that are not connected?
    Jan 2007
    us
    It very well could be the laptop. Check the voltages on the parallel port and see if they are high enough.
    Feb 2008
    Quote Originally Posted by wombat View Post
    I had a feeling about the voltage not being enough, I have no idea what they are supposed to be though. Maybe its time for me to call the help line...
    I will have to transfer the Bobcad-cam program to a desktop computer but need that stinking key again, I dont want to pay again for it. Your opinion is appreciated
    Feb 2008
    I had the same Problem. It turned out to be the power supply.
    Check to see if the fan is spinning on your power supply.
    The step moters should also get hot when the power is on, if this is not happening then there is no power going to your drivers.
    Good luck
    Oct 2007
    canada
    try the switch
    this is super simple thing to try, on the front of the x3 mill there is a white toggle switch, make sure that the switch is in the downward position. This switch is the link to the controller. (eg) manual or cnc operation.
    Feb 2008
    Quote Originally Posted by syil canada View Post
    Yeah, i was not sure on the direction but I tried both ways and nothing worked. I will be checking the Power Supply, and the voltages that come out of this laptop a a few days. Those seem like two very large possibilities. I will keep everyone posted. Thank you!
    Oct 2007
    canada
    one more thing to try is the mach3 kernel speed, the x3 mills that we sell in Canada will only work on a kernel speed of 45000. this is found in the ports and pins menu. each time you change the kernel speed you will need to close and reopen mach3.
    Jan 2007
    Does the LCD display on the head light up for you?
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    If the circuit board was not in the back panel did you check all the connections when you installed it? My SX3 had everything installed but several wires were not connected and it was basically dead. I got to looking around inside the back panel and found several wires unattached. Take a look to see if there are wires disconnected inside the panel. Contact Richard at SyilAmerica if you need assistance.
    Regards,
    Regards,
    Wes
    Feb 2008
    Quote Originally Posted by thackman View Post
    Yes it lights up nicely, I will also try the Kernel Speed as well. The mill spins (no axis movement), when you increase speed manually, but nothing in CNC mode.
    Feb 2008
    Quote Originally Posted by metalworkz View Post
    Regards,
    Will do! thank you sir
    Feb 2008
    finally had some time this morning to examine the mill and its issues.
    I took off the panel in the back to find that the power wire was not connected properly. I double checked all connections, and turned the switch on. There were led's that didnt light up before so I was happy.
    I proceeded to put everything back together and hooked my laptop up to the parallel port on the mill. I loaded some g-code and nothing happened again. So I then remembered the voltages coming out of the laptop may not be enough so I grabbed an old (working) desktop and installed mach3 and the mill still didnt respond, I tried several g-code files just to make sure it wasnt because of faulty code. The Mach3 program is still not sending inputs into the mill.
    I can hear the fan in the power supply unit humming away like never before. Im soooo close I can feel it. Any other suggestions? Maybe another g-code driver program?
  • Page 1 of 2 12 LastLast
    1. Getting my Syil Super X3
      By jinu117 in forum Syil Products
      Last Post: 04-06-2008, 06:38 PM
    2. Syil Super X3
      By tranbell in forum Syil Products
      Last Post: 08-26-2007, 11:16 PM
    3. Super X3 from Syil America
      By bmracing28 in forum Syil Products
      Last Post: 04-23-2007, 12:05 AM
    4. We just received our Syil super x3 !! Wow...
      By scyan in forum Syil Products
      Last Post: 11-28-2006, 04:56 PM
    5. SYIL SUPER X3 CNC mill System
      By antsals in forum General Metal Working Machines
      Last Post: 10-12-2006, 05:23 PM
