Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 03-16-2008, 08:19 AM
iGG1e is on a distinguished road
New revision PCB's and coolant operation
As number of us have found, the documentation (such as it is) for the older revision boards doesn't tie up with the new revision boards.
First example being the spindle controller. No RPM jumper as mentioned in the documentation on the Syil America site and the described lock mode seems to have been removed...along with half of the components. You'll see the relay positions empty in the picture.
I found some helpful pictures that helped to wire the coolant pump in this thread from simonetz:
http://cnczone.com/forums/showthread.php?t=42861
From his pictures it appears the wiring connects to the spindle board, but I have no relays on mine. Looking at the G-code board below you will see terminals called Flood and also a relay output.
Even though I wired up to the relay I can't seem to get any meaningful control of it in Mach3 and I'm not sure (yet to remove the board) what the functionality of the flood terminals is.
Anyone got any ideas?...besides the probable eventuality of wiring an hard on/off switch!
Old 03-16-2008, 09:48 PM
Chrisjh is on a distinguished road
I mentioned the lack of coolant relays on the "new" spindle controller boards to Syil China and they advised me that the coolant relays are now located on the "new" parallel port interface board. They have promised to send me a new parallel interface board with the coolant relays fitted.
Regards
Chrisjh
Old 03-17-2008, 03:14 AM
Chris do you know if the new parallel port board is different from the one in my second picture? It's a 1.3
As you can see I wired to it but can't seem to get Mach3 to switch it. If I set Output 1 to use pin 3 I can hear it click if I check the active high/low column, but no program commands seem to be able to switch it. Maybe I'm doing something wrong in Mach3?
Old 03-17-2008, 08:59 AM
presslab is on a distinguished road
I think by default Mach3 uses output 2 for the coolant. Also there is a checkbox in the port pins->spindle setup screen to turn it on, do you have that enabled?
Old 03-17-2008, 10:43 AM
Thanks presslab I'd overlooked that setting. I can now control the relay with M08 & 9 commands.
UHU Servo PCB's available jfong Open Source Controller Boards 9 12-21-2009 10:36 AM
Help with aluminium bed for pcb's djh82uk Hobby Discussion 8 11-20-2007 01:53 AM
Tinning PCB's ???. epineh General Electronics Discussion 8 11-13-2007 05:32 AM
Blank PCB's available pminmo Open Source Controller Boards 13 09-14-2005 04:27 PM
CNC & PCB's Imagineering General Electronics Discussion 6 08-15-2005 10:05 AM
