Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 03-12-2008, 02:12 PM
wombat is on a distinguished road
ATC
I saw this ATC and would like to know if any one has experience with ATCs for these little mills. Is this the only option?
Old 03-13-2008, 12:49 AM
Bugster is on a distinguished road
How about this one?
http://home.insightbb.com/~joevicar3/default.htm
Old 03-23-2008, 05:11 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
You could make your own like this one.
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 03-28-2008, 12:00 PM
I have been watching your build and am impressed but I would like a tool changer that is not table mounted as the X3 already has limited table area. With a 4th axis installed there is very little room (~7 inches) on the table. It looks like the little machine shop ATC I linked to could be mounted on the column possibly which would limit the z height of your work on one side of the table but you could still use the whole table.
Old 03-28-2008, 12:15 PM
pzzamakr1980 is on a distinguished road
If you look at another post in the benchtop forum, there is a post I made about extending x-axis travel by almost 3 inches. That would allow additional room for a table mounted ATC like Hoss's. Thats what I intend to do. I cant justify spending 1500 dollars for an accessory when the mill doesnt cost that much., and then have to modify it to work.
Old 03-28-2008, 12:38 PM
My mill came with the plates already cut like that. With out the 4th axis I am getting over 15 inches of travel.
Here is a picture from Syil America showing what the plates look like.
