| Syil Products Discuss Syil milling machines and conversion kits here! |
| Has anyone found it impossible to hear the explination on the syil site on how to set the soft limits on the X£ super mill, Can anyone send me the instructions on how to set these limits. All i hear on the syil site video is gobbled goop. |
| Are you using Mach3? http://www.machsupport.com/documentation/ try config - homing/limits to set your soft limits I think you have to turn off persistent jog in config - general config for jogging to respect the safe limits you set (courtesy Syil Canada) |
| It's easy. Home your machine. The switch to machine coordinate display. Then jog to your limits on each axis. Enter these values for x , y and z into the config - homing limits page. Then click on the soft limits button so it is highlighted in green, and you are set. You must home your machine each time you turn it on tho, but no biggy. Wade |
#10
| Hi Mad Max, I had the same problem on my lathe. I was wondering why it was so different. One day I found it. You'll find it when you hit the TAB key to get the jogging screen. This was after I had modified my screen set to put it on the manual page Mark
__________________ Insanity "doing the same thing and expecting a different result" Mark www.mcoates.com |
#12
| Hi Its me again, I think I have found out where I'm going wrong, are the soft limits past the homing micro switches. I.e. making the working area bigger than the home points. It's driving me mad, can someone tell Syil to redo their help file the sound cannot be heard and it does not match the video. It will be in Syils interest because someone will crash the axis into the castings one day. I've been using the X3 and Mach 3 programming without the limits set! |
| Need Help!- HOME LIMIT SETTINGS IN EMC2 | Gads | LinuxCNC (formerly EMC2) | 5 | 02-13-2008 05:50 PM |
| Fanuc 11T Soft limit troubles on Slant-1 | shupej | Fanuc | 2 | 09-26-2007 04:30 PM |
| Anyone know the 15-T well, what's this soft key do? | Dent | Fanuc | 2 | 08-30-2006 05:08 AM |
| V2XT Quilt limit deceleration settings | Spin | Bridgeport and Hardinge Mills | 0 | 02-16-2006 09:10 PM |
| Limit switch settings | Stevie | TurboCNC | 0 | 05-24-2004 07:16 PM |
