| Syil Products Discuss Syil milling machines and conversion kits here! |
Hey All, I am quite the newbee when it comes to machining. I have made a few pieces, but the distances are not right. My holes are smaller than what the model says. Currently all in Imperial mode. I know I have my tool sizes and paths correct. Seems the mill is just a little off. Could this be due to my driver test scoring a 25 when the ports n pins was set at 35? How do I test my machine for 35 and 45? Can I change mach3 to think its in MM mode? Can you please tell me the steps and speeds for my motor tuning page? I am running at 25000hz (the slowest kernal speed) Thanks Joe |
| Joe If your getting consistent machining results but the size is off then steps per unit being incorrect is the most likely culprit. Mine is set at 10160 steps per inch. At ten microsteps. Your microstep might be different. Check the driver manual, it will tell you the dip switch settings for microstep setup of the driver. About 50 to 60 inch per min on the X and Y is OK for most users. Bit slower on the Z Greg |
| Hi, Joe If your not getting the proper cut length and your circles are small, You need to increaser the Steps Per value in Config, Motor Tuning, For each Axis. Steps Per setup exam. stepper 200 steps per 1 turn X 20 turn screw per inch = 4000 steps Per. If you change the 25 kernel speed to 35K you need to restart Mach3, The steps per stays the same but you will need to re-tune the Velocity & Acceleration settings. Hope this Helps, Chip |
On the syil site I found: Ball Screw is Metric 5.08 TPI Stepper per rev 200 Micro Steps 2 4 5 10 20 25 50 100 2032 4064 5080 10160... Maximum Traverse Speed at 25000 Hz 738 369 295 148 74 59 30 15 Inches Per Minute So, in mach3, how do I know which value to use for steps per and velocity? Thanks for all the help, Joe |
Mariss, designer of the Gecko drives, says any thing over 10 microsteps in a stepper drive is a waste. So I go with ten. But by all means use 25. That's OK. Then steps per inch will be 25400 Greg |
#11
OK. Start with the 'humour'. Does anyone else 'love' the fact that Syil, quote the ball screws as 'Metric', and give their pitch as 5.08 teeth per inch... In fact (of course), the threads are 5mm pitch. The steppers are 200 steps per rev, so the 'default' single stepping size, working in metric, is 5/200mm = 0.025mm Now, the question of how fine to microstep, is that normal steppers, go very significantly 'non linear' in their responses, as you do smaller steps, so though a controller may be able to offer you hundreds of micro steps, the 'real' limit on reasonable resolution, will be much larger. In general different manufacturers make slightly different 'claims' in this regard, but normally 8 to 16 microsteps, is the 'upper limit'. However using smaller microstep numbers, to make the maths 'easier', is still worthwhile, and in some cases the drives will be smoother. So, using 25 microsteps, gives you a 'nominal' step size of 0.001mm, which is nice to work with, and makes setting up easy. ![]() Best Wishes |
| Motor Tuning | Smitty911 | Gecko Drives | 6 | 10-16-2007 04:40 PM |
| Motor Tuning | dwacker | DIY-CNC Router Table Machines | 8 | 04-30-2007 09:50 PM |
| Motor Tuning ??????????? | Biggermens | Mach Software (ArtSoft software) | 2 | 03-14-2007 09:52 PM |
| Motor tuning and units confusion | Konstantin | Mach Software (ArtSoft software) | 1 | 02-26-2006 05:34 PM |
| Motor Tuning | PEU | Mach Software (ArtSoft software) | 3 | 09-26-2005 11:48 PM |
