| Syil Products Discuss Syil milling machines and conversion kits here! |
Hi Guys I have a SX3 Which I am converting to CNC using a Syil kit. I have completed the mechanical installation ok. Now the fun starts,I am not real great on the electronic stuff so I need heaps of Help. I am using a trial version of Mach 3. The x and y 28 N stepper motors have 4 wires and the Z 34 N has 8 the manual shows a diagram but which goes to where ? at this stage I hve not installed limits. I connected the motors to the drivers to what I think is right, but the z dos'nt work at all, the Y seems OK. The X goes the same way when I use the jog function + or - if I change the wires I get the same problem but in reverse. I also gather I need a metric XML file. Hoping you guys can help |
| Howdy, I'm not farmiliar with the syil kit but I'll put my 2 cents in anyway. The X going in one direction problem sounds like an issue on the input side of the controller. Either you have miss configured Mach or you have a wiring problem. Mach generates 2 signals to move the motor, a direction signal (dir) and a move signal (step) sounds like your dir signal is not working for the X. Does the controller connect directly to the parallel port or do you go via a breakout board. Have you triple checked the output settings in Mach match your board? Your description of the Z axis problem was pretty vague, but keep in mind when you connect it to the control board you should have 2 pairs of wires(each going to the common) and 4 single wires connected. Again I'm guessing what the controller looks like. Where abouts you located? I'm sure someone local wouldn't mind helping out with the wiring Cheers, Scott |
Regards, Neil - Bass & Tuba Player.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Old Tool where are you? I did the Syil conversion too. I have the PDFs for thr syil motors somewhere. They have the conections and wire colours. Let me know if you need them and I'll dig them out. Greg in Geelong |
| Greg I am in the Gold coast Qld I will send my email address as I will be very grateful for the info. Peter |
| hi.total ignorant to cnc but buying one | jking | CNCzone Club House | 3 | 11-12-2007 08:06 PM |
| Ignorant Newbie, here | CaptYellowbeard | WoodWorking | 3 | 07-16-2007 08:57 PM |
| Ignorant newbie question | DayneInfo | Vectric | 12 | 11-20-2006 10:51 AM |
