Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 01-15-2008, 12:47 PM
lagfish is on a distinguished road
SX3 stepper size?
Anyone know what torque steppers do the the Syil X3/SX3 use for the x, y, and z axis? Thanks.
Old 01-15-2008, 04:03 PM
Greolt is on a distinguished road
X and Y are Nema 23 260oz
Z is Nema 34 don't know the oz
Greg
Old 01-15-2008, 04:56 PM
gerryv is on a distinguished road
Stepper Torque
A good question. 260 oz on X and Y are in the Talg & Sherline league aren't they? I don't know enough to know if this is adequate or not so also hoping for comments from those with experience with these. Based on what seems to be the norm, I do hope the Z is more rather than having to start hanging counterweights off the head.
The obvious related question, I imagine, is whether or not the controller has enough "juice" to make the most of these steppers max capabilities when they are all working together.
I'm not trying to be negative; simply doing my homework as I'm also interested in getting a CNC mill and lathe setup around this size.
Old 01-15-2008, 10:38 PM
Is the Syil X3 adequate to do light production work? As gerryv said, 260 oz-in seem a little small for this machine. I know the x3 is not meant to be a large production machine, but I would like the possibility of doing LIGHT production work in the future. With that said, is the machine itself the limiting factor, or are the steppers/drivers the limiting factor when doing very heavy cuts?
Old 01-15-2008, 11:07 PM
Old Megawatts is on a distinguished road
Power of Stepper Motors
I have one of the first SX3 machines and haven't had any problem with lack of power on any of the axis's. I can tell you from experience that the X axis will snap off a 3/16" end mill without slowing down. I haven't had the pleasure?? of breaking anything larger yet. It will handle a .100 cut in mild steel with the 3/16" mill with no problem.
OM
Old 01-16-2008, 01:23 AM
neilw20's Avatar
neilw20 is on a distinguished road
No counterweights.
RE above highlight. See:
http://www.cnczone.com/forums/showthread.php?t=50292
Steppers are more than adequate, running X,Y rapids at 2500mm/min (100 IPM)
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Stepper Size Recomendations millman52 CNC Plasma and Waterjet Machines 0 01-19-2007 04:35 PM
stepper size required bru Stepper Motors and Drives 1 12-24-2006 02:38 PM
Stepper motor size corydoras Open Source CNC Machine Designs 2 10-21-2006 11:13 PM
stepper motor size nymachinist Mini Lathe 1 02-21-2006 04:34 PM
Z-axis...what size stepper ? dmoore3008 DIY-CNC Router Table Machines 1 05-08-2003 07:13 PM
