Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 01-11-2008, 03:59 AM
MadMax is on a distinguished road
Difficult C6 move in: has anyone disassembled one?
I've got a difficult move in coming the Monday. I've got to move a 450lb C6 up a narrow flight of stairs. Has anyone disassembled one into sub assemblies to lighten this lathe?
I've been looking for an online exploded view diagram without any luck.
Old 01-11-2008, 08:32 AM
JDsto is on a distinguished road
We packed mine up a flight of stairs, we got 4 of us on it, and it wasn't bad at all. Seems it would be a lot easier to find some people to help you than to disasemble the lathe.
Old 01-12-2008, 01:53 AM
Thanks JDsto!
I should be able to find enough help to schlep my lathe upstairs. It's hard to picture what lifting 450lbs of steel is like.
Old 01-21-2008, 05:08 AM
rad45 is on a distinguished road
Hi People,
There is not 400 pounds in a C6 Maybe 280 plus change. I tool the tailstoock off mine, then, after removing the R/H end bearing for the leadscrew off, I was able to remove the saddle and all it's fruit. Obviously the milling head was already on the floor. I then moved it to where it had to go standing on it's tailstock end with a stack truck. To get it up onto the bench, I laid a plank there, smeared some grease on the plank and slid it up the plank. On level ground three can move a C6 with all the fruit. So your guesstimate of 4 to go up a flight of stairs should bolt it in..
Russell
in Perth, Western Australia
Why is EVERYTHING so difficult?!? (meshcam / SW hate) ClemsonGirl General CNC (Mill and Lathe) Control Software (NC) 8 04-22-2008 11:04 PM
Material difficult to burn ben_heinman General Material Machining Solutions 0 12-27-2007 03:21 PM
Has anyone disassembled a Tormach into subassy to make a difficult move in? MadMax Tormach PCNC 5 12-06-2007 07:50 AM
Security/marking compound to know if parts were disassembled? SRT Mike General Metalwork Discussion 28 11-08-2006 06:49 PM
How difficult is it to add a tool changer to a TM-1? KevinWilkins Haas Mills 2 05-03-2006 11:01 AM
