Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-17-2007, 12:13 PM
thackman is on a distinguished road
Default kernal speed in Syil inch profile
What is the default kernal speed in the SyilAmerica X3 inch profile? I tripped a breaker and the PC shut down hard. Every since then Mach has been complaining that the kernel speed of 25khz is to slow for the motor tunings. I suspect that I need to set the kernal back to 35khz but I've customized my profile quite a bit over the past few weeks and didn't want to accidently over write it by reloading the original from CD. Can someone post the default kernal speed and a few of the motor tuning numbers so I can see if I need to re-do those as well.
Old 12-17-2007, 03:28 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
I can't help you with the units, but the profile (metric) I received was 35Khz.
Old 12-17-2007, 03:41 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question Problem with PC.
25 Khz I think is correct.
I had the error message come up because XP was making the PC busy when Mach3 started.
Make sure no rogue programs are running.
When Mach3 starts it enables it's driver, and at this moment the PC must be healthy and not busy.
Mine is connected to a network, and every so often it goes off into the weeds at the wrong time. Restart Mach3.
Use Ctrl-Alt-Del to see what else is running.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
default units canadamaxxer Solidworks 11 10-07-2010 01:05 PM
Default SL-20 parameters question? PaintItBlue G-Code Programing 0 11-01-2007 05:48 PM
Default feed override and manual jog speed settings? InspirationTool Carken Products (Deskam, DeskCNC etc) 0 02-22-2007 04:04 PM
Mastercam 9.1 default settings Fatty Mastercam 2 06-28-2006 11:04 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 09:27 AM
