Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-07-2007, 11:13 PM
MadMax is on a distinguished road
C6 lathe questions
I've just ordered a shiny new C6 lathe from SyiL Canada (Thanks Keith!) and I'd like to start planning for its arrival. I wish there was more technical info on SyiL's site. Could someone with a C6 help me with these questions?
-input voltage (110v 60Hz AC?)
-spindle bore
-spindle nose thread
Has anyone worked out ballscrew covers? I'd like to keep them clear of chips. I think it's asking for trouble to leave them exposed.
Old 12-10-2007, 09:13 PM
Journey_Man's Avatar
Journey_Man is on a distinguished road
C6 Lathe Answers :)
Glad to see you are getting a New C6 Lathe!
The input voltage is std. 110
The Spindle bore is .812
The Chuck is mounted on the Spindle with 3 M10x1.5 Studs & Nuts.
Before you remove the chuck for the first time, Take a center punch or a metal stamp and mark the Mounting Flange and the Chuck,So that you can always mount it back to its Origional Factory Location.
The "Z" axis Lead Screw has a cover on it and it wont get Chips on any part of it.
The "X" axis Lead Screw is concealed and wont get any chips on it either.
Use Way Oil (if you can get it) to lubricate the ways and everything else.
Keep it Oily.
Use High Quality Tooling.
I use Dorian & Kennametal...
It is not hard to hold a close tolerance with the Lathe if you have a solid tool post and good tooling. I took the Compound Slide off of my Lathe and made a riser block and Put a Quick Change tool Post on it. Very Rigid!
Ok well I hope to hear more about your New Lathe and if you need any help,I will be more than willing to give it to you Bob
Old 12-13-2007, 11:25 AM
Thanks Bob!
The pics of the C6 made it look like the ballscrews were exposed.
MasterCam lathe Questions mefull Mastercam 12 09-16-2006 09:38 PM
Haas Lathe Questions - Lots 1ctoolfool Haas Mills 6 08-13-2006 06:47 PM
new guy with a cnc lathe general questions LOGBOSS General Metal Working Machines 1 05-07-2006 04:41 PM
Mach3 lathe questions JFettig Mach Lathe 5 03-16-2005 05:43 PM
Lathe machining questions devinchi General Metal Working Machines 5 02-25-2004 10:17 AM
