Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-01-2007, 11:01 PM
jinu117 is on a distinguished road
Recommedation on Vacuum table?
For SX3.
I found out I need to do some cutting on thin metals (probably better suited for router but I don't have space for any more machine :P)
Any recommendations? Lower the price better, smaller the power requirement better... of course while having good hold down strength
Lot of it will be cut through so recommendation based on the use will be helpful too.
Thanks guys
Old 12-03-2007, 10:59 AM
dafowfidy is on a distinguished road
Ever try double sided tape? If you can get away with running it dry double sided tape works great as long as you have enough flat surface area. See McMaster-Carr #76405A15 for reference.
Old 12-03-2007, 11:39 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Maybe you can tab(bridge) the part in the blank at 4 corners etc. for some of the parts. Also foiling(leave .001" mat'l) the part in several locations does well at holding things together in aluminum and usually cleans up fairly easily. I know these are work-arounds and you probably want the vacuum table anyway, but thought I'd suggest them. Good luck finding an affordable vacuum table and let us know what you find.
Regards,
Wes
Old 12-03-2007, 02:53 PM
gn3dr is on a distinguished road
Hi
Have a look here - an ebay seller in Germany who seems to sell a lot of them.
http://cgi.ebay.co.uk/Vacuum-table-2...QQcmdZViewItem
I don't have one of these and don't know the seller but I have seen a few different types go on ebay for OK money.
Old 12-03-2007, 05:10 PM
sickpaint is on a distinguished road
x3 vacuum table
Seen one on youtube the other day here is a link to it I believe..
Old 12-03-2007, 06:05 PM
Greolt is on a distinguished road
The one shown in the video is not so good for jobs that are cut through.
However if you have a vacuum source then make custom hold down jigs to suit repeat jobs.
Something along the line of the one shown would work, except instead of a square grid for the sealing material
you could make channels to suit a particular profile.
If you already have a CNC mill making the jigs is easy.
Greg
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 10:30 AM
Vacuum Table CNCRob Work Fixtures and Hold-Down Solutions 146 04-15-2009 04:57 PM
DIY Vacuum Table Baudros DIY-CNC Router Table Machines 5 04-07-2007 12:57 AM
vacuum table dmglass General Metalwork Discussion 3 11-16-2006 05:46 AM
Vacuum table balsaman DIY-CNC Router Table Machines 11 01-05-2004 08:18 AM
