Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-23-2007, 05:10 AM
krazatchu is on a distinguished road
SX3... improper Mach3 pinout ?? no steppping
Hi all...
I got my mill direct from Syil China...
It seems the pinout doesn't match the Mach3 xml config file....
After installing the latest version of Mach3... and loading the Syil America config file.... I came to the conclusion the pinouts are wrong for my mill... I also tried the Australian file (it's metric)....
I got an "Installation Instruction Manual" with my mill... On page 8, it has the pinout, but it doesn't indicate the active state (hi or low)...
Here is the pinout listed in the manual... (function, pin)
x pulse 7
x dir 17
y pulse 6
y dir 8
z pulse 5
z dir 16
a pulse 4
a dir 14
spindle pulse 2
spindle dir 1
signal 1 3
signal 2 9
x home 12
y home 13
z home 10
a home 15
e-stop 11
Now... When i configure it as to the manual.... The inputs work like they should... E-stop... X home... Y home...
But... the steppers don't jog in Mach 3... the ouput pin lights in the diagnostic screen don't light in Mach 3 either... only the inputs show responce...
So far.. I checked and tested... the stepper drivers are getting about 48 volts.. the red light comes on the drivers...
The control board gets about 14 VAC from the small transformer beside it...
I haven't checked to see if the parallele port is outputing 3.3 volts or more...
My parallel port is enabled and the driver is loaded... its running on x378....
So... other than checking that the parallel port is outputting a high enuf voltage (MSI K8N Neo4 MB / AMD Athlon64)... and not knowing what should be hi or low for the outputs... is there something else I have missed?
Thanks,
Michael
Old 11-23-2007, 05:03 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Hi Michael,
There are some great troubleshooting videos on the Mach support website, and if you haven't viewed them already you might find the infromation helpful in finding the problem with your setup. I had to reverse the homing of one of my axis and a defective Y axis home switch and found the Mach support videos very helpful in my case. Do you have power to the axis drivers? Sounds like maybe the wire harness to the stepper drivers is not connected. I had a similar problem with no stepper power when I first tried my SX3 and found the wires connecting the drivers were not connected. Hope you are able to get it running soon.
Regards,
Regards,
Wes
Old 11-23-2007, 07:43 PM
Hey~
There is power to all four of there drivers... 48 Vdc, and the stepper motors are getting warm...
I will check the port voltage (3.3v vs 5v)... however I'm not sure this is an issue with the SX3... The other thing I need to figure out is the active states (hi or low) of the various outputs...
And what should the port setting be in the bios?... I've seen ppl say both ecp and spp..
Thanks,
Michael
Old 11-23-2007, 08:20 PM
Greolt is on a distinguished road
G'day Michael
Fairly sure it won't be the voltage on the LPT. The controller board that Syil use buffers the logic signals.
Are you sure you have the port address set correct? If your not sure about that go and look at the introduction video on the Mach site.
Post your XML and I'll have a look.
Greg
EDIT: OK I did not read your original post properly. You have inputs working.
Have you set the same port number for outputs?
Old 11-23-2007, 08:35 PM
Yes, everything is set to Port 1...
I just changed the port type to EPP and will resistall Mach3 R2.60...
Then I will use the Syil America XML file... and rewrite teh proper port numbers in ... without changing the active state setting (hi or low) ...
After that... I dunno...
Old 11-23-2007, 09:47 PM
Ok, Reinstalled and re-setup the config file...
Also tried Mach2
Same thing.. I can sense the inputs in Mach3... but the motors dont turn...
Something I jsut noticed after going thru the Mach3 setup video...
Under device manager... my LPT1 resources... I have two I/O ranges...
One is 0378 - 037F
Second one is 0778 - 077B
The Mach3 setup video only shows the first range...
Could this be the problem??
Old 11-23-2007, 10:31 PM
Hi agian~~
Here are a couple of pics of the LPT1 port screen and the Mach3 Diagnostic screen....
The controller in the back of my mill says "ECTL" and "East Crystal Five Axis CNC Board Rev 1.3"....
Is this the same board in the American SX3?? (or other countries..)
Thanks,
Michael
ID:	47263   Click image for larger version
Old 11-23-2007, 10:42 PM
Michael
0378 is the number you want. When saved Mach will convert it to 0x378
Post the XML you are getting inputs working with. Let's have a look at it.
When you say the motors won't run, can you be more specific?
What exactly are you doing? Do the DRO's run as if it is moving?
Greg
Old 11-23-2007, 10:52 PM
The motors get warm... but they don't turn... they don't make a sound either..
The DRO's do change as I press the buttons on the number pad... also change if I use the pop out (DRO) thingy (tab key)...
Here is the custom XML file... its jsut a modified version of teh Syil American XML....
Thanks,
Michael
Old 11-23-2007, 11:27 PM
Take these three things one at a time,
On my X3 I don't have the "active low" ticked for motor outputs. I s'pose you have tried with them crossed.
Have you done the driver test? What sort of result did you get?
Set it to "Sherline Mode" then restart and see if they run.
Greg
  #11   Ban this user!
Old 11-24-2007, 12:34 AM
Hey~
1) I did try them both ways... but I may have had the different pin configs then... I will try them agian on Monday, since the mill is at my office...
2) The driver test showed a nearly straight line with minimal interference...
3) I will try Sherline mode on Monday as well...
I also ran the port finder and it came up with 378....
Syil China said they would get back to me by email with the correct XML config file...
Thanks,
Michael
  #12   Ban this user!
Old 11-24-2007, 12:46 AM
Oh,.. here is something intersting...
While at my office, I checked my main work pc... It also had two ranges for the printer port resources in device manager... see post #7 above for the mill pc...
It, as well as the mill control pc are both AMD systems...
My work pc being a socket 939 dual core Athlon 64 on an Asus MB...
And the mill is a socket 939 single core Athlon on a MSI MB...
Now... I just checked my wifes pc, it's a core 2 duo Intel system on an Asus MB ...
And it has only the single range of x378...
My home pc, core 2 quad intel on an asus MB doesnt have a parallel port...
But my TV pc is a P4 so I will check it asap (its in the bedroom and someone is taking a nap)...
Hmm.. perhaps the extra range is confusing the output...
#23-305-DS8A Pinout Richie800 Hobbycnc (Products) 2 11-15-2007 02:11 PM
Improper V-Ready Off Alarm??? Crashmaster Fanuc 2 09-18-2007 07:31 AM
DB9 pinout cabling miguisu Machine Problems, Solutions , Wireless DNC, serial port 0 05-23-2007 06:21 AM
Fanuc 11m error message. improper number of axis kmcmillen571 Machine Problems, Solutions , Wireless DNC, serial port 0 04-01-2007 07:14 PM
svo13 y and u improper v_ready off stanman Machine Problems, Solutions , Wireless DNC, serial port 10 11-15-2006 08:11 AM
