| Syil Products Discuss Syil milling machines and conversion kits here! |
Hello~ I just got my mill early last week... I haven't had much time until now to start cleaning it.. So, I downloaded the "Introduction_to_your_machine.pdf"... and followed the instructions... upto page 3... "Using your superhuman strenght..." The motor mounting plate won't slide away from the bed... The dowel pins must be in too tight... When I pull on the table, the stepper and screw spins... If remove the stepper and then the bearing... I don't think it will slide off to the left as it will catch on the bottom... And it wornt slide of the to the left... I guess my only choice is to release the preload on the bearing and then slide the table off the right side... Any suggestions ?? Thanks, Michael |
| Hi Michael, I think it would be better to try and pry off the motor mtg. plate than to remove the table by other means. Even if the dowels are tight I would think the plate could be pried off begining with a very thin wedge like a sturdy putty knife and then proceed with something thicker and even a pry bar until it comes off the dowel pins. Just an idea, and I hope you are able to remove it and finish the clean-up process without too much extra effort. Best regards,
__________________ Regards, Wes |
| Good idea! I have a couple of putty knifes handy, so I'll give that a try ... I already spayed some wd40 on it last week... but there isn't even a hair betwen the two pieces... not sure if a putty knife will even get in there... thanks, Michael |
| Woot~~ That worked great, thanks! My drywall knife isn't much good for drywall anymore.... it chipped a bit, will have to grind it... I had to do both the X and the Y like that... Now to do the spindle mod, I think I might need a puller to get that small sproket off... Thanks, Michael |
| Hey~~ the pulley change went without a problem... the pulley slid off with a tiny bit of prying ... The bolt that was in the bag with the spacers for the new pulley was much too long, so I used the original spacer and philips screw... Thanks |
| THK slide bearing | Bill Davis | Mechanical Calculations/Engineering Design | 2 | 08-26-2006 06:31 PM |
| cross slide | nantz | Benchtop Machines | 0 | 07-12-2006 06:09 PM |
| Air slide question | 2muchstuff | Linear and Rotary Motion | 8 | 03-09-2006 04:08 PM |
| misumi slide | Felipe | Mechanical Calculations/Engineering Design | 3 | 06-28-2005 08:40 AM |
| Corian as a slide? | chuckknigh | DIY-CNC Router Table Machines | 13 | 04-27-2004 07:44 AM |
