Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-08-2007, 11:53 PM
bullseye is on a distinguished road
Super X3 Problem
Today I was running some parts and all of a sudden all axis's stopped in the middle of a program but the DRO still said they were moving.....
I try jogging and nothing but the DRO on each axis moving
like I lost all communication to the machine.....restarted Mach3 and still same
also when power is on the Steppers don't even get warm anymore, Seems like no power to them.......hope its not a Burned Board
power on machine turns on and spindle runs fine,
been running Great till now
any ideas............thanks
Old 11-09-2007, 01:17 AM
Greolt is on a distinguished road
I take it that because this is in the Syil forum therefore this is a Syil converted X3.
Is the stepper power supply still supplying power to the drivers? Are the LEDs on the drivers lit?
How about the small transformer which provides power to the controller board?
Greg
Old 11-09-2007, 04:35 AM
Yes its Syil Converted..
I never noticed any led's when it was working......where are they
only seen a green led when power is turned on
Not sure about the transformer....im not an electrician......
Old 11-09-2007, 09:15 PM
no lit leds on drivers....
tried another computer & cable with same results
Old 11-10-2007, 02:07 AM
Sound like no power getting to the drives. Do you have a multimeter?
Probably better if you have a friend who does and knows how to use it.
Check to see if the power supply is sending power to the drivers. Should be 48 v.
The power supplies that they use are a but prone to stop working. Mine blew up quite spectacularly. Replaced it with a linear supply.
Contact where you got it from and they'll most likely send you another. They're fairly used to doing that I think.
Greg
Old 11-10-2007, 02:33 AM
Greg
Thanks .....would the spindle still work with a bad Power Supply ?
Old 11-10-2007, 03:42 AM
Yes. The power supply I am referring to only provides power to the stepper drivers.
If it is dead, which I think is likely, that will not affect the original Seig side of things.
Greg
Old 11-10-2007, 10:54 AM
Greg
OK....Thanks alot....That sounds like the problem then..
I will have a electrician friend put a meter on it.....
Where did you get your linear supply.....?
Old 11-10-2007, 02:12 PM
I made mine.
As I said the Syil people are fairly used to replacing these power supplies. I know of several who have had theirs replaced free of charge.
Ask and you will probably receive.
Greg
Old 11-10-2007, 06:37 PM
I made mine.
Greg
It is the Power Supply...Thanks...
  #11   Ban this user!
Old 11-10-2007, 10:16 PM
syil is on a distinguished road
i have been infrom syil america.don`t worry.i`m very confidence of syil america service.
Syil China
Xushuo
Direction,Commitment,Follow through
Old 11-11-2007, 12:05 AM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
Sorry you're dissappointed. We don't monitor 3rd party forums just what customers email or call us.
We haven't had too many power supplies go bad. About 3%. They are extremely reliable. Sounds like yours is bad. Our service is top notch, just wish you would have emailed us first instead of waiting to hear back on a forum.
Direction, Commitment, Follow Through
Sieg Super X3 Halfnutz Benchtop Machines 28 11-02-2009 02:45 AM
SUper Mini Startup Problem JerryH Haas Mills 5 05-14-2007 11:22 AM
Thinking about a Super x3 FroggyOne2 General Metal Working Machines 2 04-18-2007 04:23 AM
My NEW SUPER X3 CNC Mill danswaay Syil Products 28 02-13-2007 07:48 PM
Super X-3, anybody else want one? bryanrabb Benchtop Machines 0 12-13-2006 05:22 PM
