Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-01-2007, 06:01 PM
stoneyberk is on a distinguished road
seting up my new syil x3 cnc mill.
Hey all.. I'm just starting to setup my new x3 mill and thought I would ask if there any tricks out there for seting them up? at least as far as the software goes. also what type is the best for these cnc mills? I'm curently installing the artsoft mach3 software so far it's fairly simple but I just got started...Also I have a friend looking for a used syil x3 cnc mill if anyone know of someone that has one for sale please let me know thanks guys...Floyd
Old 11-02-2007, 06:15 PM
Mike F is on a distinguished road
Floyd,
It's well worth taking a bit of time over the de-greasing and cleaning. I would also strongly recommend lapping the ways - it doesn't have to be anything really onerous but a little work here makes a big difference. Also, after you put it all together again, check the limits of travel and that the ballscrews are not binding. My Y axis was real difficult to move at one extremity but was relatively easily put right. I have just started a thread to show what I did.
Good luck with your machine, I think you will grow to love it.
Mike
Old 11-06-2007, 01:57 PM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
Lapping is quite easy and does make a good change to smoothness and maximum traverse speed. Accuracy doesn't change.
I would allocate about 2 hours for the process. It's also wise to get the correct supplies in hand before you begin. I use several grades of sandpaper and a machinist granite, but other people like lapping compound. I like the sandpaper because I can use it easily with the machinist granite. I go upto a 1500 grit, (Overkill and then some) but I like to make them shine like glass. 800 grit would be perfectly fine.
Mind you, lapping is completely optional. For most people I would say you wouldn't notice much benefit.
Direction, Commitment, Follow Through
Old 11-06-2007, 03:03 PM
thackman is on a distinguished road
SyilAmerica,
When lapping the ways it seems that the top surface is easily enough done with a machinist granite but what about the inside angled part of the ways that the gib rides on. Should that be lapped as well and how?
Old 11-06-2007, 03:33 PM
Gold Member
I use a machinist level and wrap paper around it.
Old 11-07-2007, 04:55 AM
david_geng is on a distinguished road
Please feel no offense, I'm just a beginner trying to find out the truth. Although some special work, like the lapping, sounds exciting, does it really improve the accuracy? which can be offset by other things, for example, the backlash of the ball screws. I would be very interested to see some real test number.
Old 11-07-2007, 01:49 PM
David,
It doesn't improve the accuracy but it does improve the movement of the table, making it much freer and a consequence of this is that the steppers do not have to work as hard, accelerations and feeds can be higher too.
Mike
Old 11-11-2007, 12:10 AM
Gold Member
Well said Mike, that's exactly correct. If you are doing alot of plastics or similar materials, it would help in your overall speed. Other than that, it will not effect accuracy.
Old 11-11-2007, 04:35 AM
Oldmanandhistoy is on a distinguished road
This thread imo is worth a read before starting lapping your machine.
http://www.cnczone.com/forums/showthread.php?t=11874
Old 11-12-2007, 05:59 PM
Thanks guys I havent had much time lately to work on the mill or respond to these post I got way to many things going on at the moment, I will try to reply to these post later,,,Thanks again,,Floyd
Does Syil offer 5 axis CNC mill? RoboticsMD Syil Products 7 12-06-2010 11:46 AM
syil/sieg X3 cnc mill. stoneyberk Benchtop Machines 1 10-31-2007 02:49 PM
Video of my Syil Mill in Action Chrisjh Syil Products 1 09-12-2007 06:47 AM
Is there any document or FAQ for the Syil SX3 mill? david_geng Syil Products 5 05-06-2007 01:47 PM
Steper Motor & Driver Seting--- Please Help Chivo Stepper Motors and Drives 4 08-24-2005 07:15 PM
