Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 10-25-2007, 05:26 PM
bullseye is on a distinguished road
Z losing Step going down
What are you guys running as far as Rapids on Z...
I set it at 80 as syil suggested and then lower it in Mach to 20% and still lose steps only going down. all in the air..........rapid up is fine
What is the best setting you guys have found........
Old 10-25-2007, 10:23 PM
roonster71 is on a distinguished road
I had a similar problem today on my router the z axis was drifting down. i figured out that my parrellel interface card (cnc4pc c-1) didnt have enough amperage going to it
i replaced the power supply with a TRUE 5v 1amp wallwart and it worked fine after that
i also changed my step and dir pulse to 5
hope this can help, good luck!
Old 10-25-2007, 11:29 PM
Thanks ....I think I just need to tune the Z stepper motor, when I feed it down its fine......
im using 45000 hz ...will drop it to 35000 and try it
Old 10-26-2007, 02:10 AM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
80 isn't recommended on the Z. Velocity is default at 55 on the Z 80 on X and Y. Sounds like your acceleration is too high.
Direction, Commitment, Follow Through
Old 10-26-2007, 06:38 AM
OK .. Thanks alot
I will get it tuned up today.......
Old 10-26-2007, 05:26 PM
Thanks that fixed it.......
Old 11-01-2007, 01:22 AM
Gold Member
Great to hear. The machine is very reliable and very accurate when you set the motors to the correct numbers. With setting the velocity and acceleration too high it pushing the motors beyond what they can do and misses steps. That makes for poor accuracy. Have a great time making chips!
Old 11-01-2007, 05:48 PM
Thanks.....I Love My Super X3....Very accurate and smooth as silk....
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
TORQUE: FULL STEP vs half step Glidergider Stepper Motors and Drives 0 02-27-2007 02:02 PM
step by step instruction for building controller avengine CNCzone Club House 0 04-21-2006 07:24 AM
Cause For Losing Steps? FLUTE HEAD TurboCNC 7 06-14-2005 07:54 AM
Single Step/Half Step Question Hawkeye DIY-CNC Router Table Machines 4 11-20-2003 10:28 AM
