Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 09-21-2007, 06:03 PM
Involute is on a distinguished road
How to increment a parameter in G-code
I'm a G-code newbie and can't figure out how to increment a parameter with it. E.g., I'd like to use the expression #1 = #1 + .001 (i.e. increment parameter 1 by .001), but Mach won't accept it, and the manual even says you can only have a real number on the right side of the =, nothing else (e.g. no expressions). I've posted this question on the Mach forum and can't get a straight answer (e.g. someone suggested I get a copy of Alibre and MeshCAD ???). Is something like this possible? Again, I'm a newbie, but it's pretty surprising if it isn't. Thanks.
Involute
Old 09-21-2007, 06:36 PM
cncwhiz is on a distinguished road
Are you sure that you are talking gcode or macro? You need to talk to someone who does macro programming.
Old 09-21-2007, 11:24 PM
micsit1 is on a distinguished road
Try this
#1=-0.5
#2=0
G21 G40 G80 G90 G00
Z2
G1 F30
Z[#2]
G4 P1000 (Dwell 1 sec)
(Calling sub O124)
M98 P124 Q5 (Repeat 5 times)
#2=0
G00 Z[#2+2]
Z[#2]
M30 (end program)
O124 (this is a sub)
G1 Z[#2] F30
#2=[#2+#1] (Step decrease Z by value of #1 i.e. 0.5)
G4 P1000
M99
You could also do it with incremental G91
Michel
File Type: txt Increment.txt‎ (230 Bytes, 92 views)
Old 09-22-2007, 12:59 AM
Thanks, Michel. I'd just figured out my problem was not enclosing the assignment expression in brackets. Now my G-code runs like a charm.
Involute
Jog Increment gleas Larken 1 07-24-2007 12:07 AM
Changing Fanuc part counter increment? gearsoup Fanuc 4 06-23-2007 07:50 AM
Increment the Z. civilseal Machines running Mach Software 6 03-06-2007 08:46 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
Stepper Increment Advantages CNCadmin General Metal Working Machines 2 03-09-2004 08:36 PM
